Lou305sr Posted August 27, 2005 Report Posted August 27, 2005 Hey how you guys doing? Can any one tell me the part number for the Idler pulley on a 97 gtp? The one between the crank and the AC pulleys? Thanks in advanced. Quote
mfewtrail Posted August 27, 2005 Report Posted August 27, 2005 You should be able to find the part # if you search for "pulley" or something similar here. http://www.clubgp.com/cgi-asp/partslist.asp Also, you might want to poke around clubgp a bit, I seem to remember someone posting part numbers for aftermarket pullies(that can be purchased at local parts chains) that are far superior to the stock ones used in the earlier year GTP's. Quote
john99gtp Posted August 27, 2005 Report Posted August 27, 2005 Pulleys If you have over 40K on the car, you should seriously consider new tensioner and idler pulleys. The stock plastic ones are crap. The bearings get hot, grease dries up and they seize. Once they seize they tend to fragment and take your belt with it. I would suggest dayco metal replacements. They are a little wider and a lot better build. Not a hard install. If you can do spark plugs you can do these. Dayco Part numbers are as follows; Idler Pulley (Smooth 3.5") - #89006 Idler Pulley (Grooved 3.0") - #89009 Tensioner Pulley (3.0" (Used for the NA 3.8 also)) - #89007 Tensioner Pulley (SC Drive 3.0") - #89007 The grooved idler and the larger smooth idler go on the SC drive belt along with the SC Tensioner Pulley. The accessory belt only uses one tensioner pulley. Quote
Lou305sr Posted August 28, 2005 Author Report Posted August 28, 2005 Thank you very much sir... I actualy did end up getting the 89006 from Dayco about an hour ago... Im also saving those other part #'s just in case 8) ... Quote
