MoTox8410 Posted August 23, 2005 Report Posted August 23, 2005 just pulled the plugs on my my 3.4 and 1/2 the insulator appears to have a dark purple tint to it and the other side is semi-normal... fyi::they are the bocsh platnium series 2 :oops: there is only like 15000 miles on these plugs but i think im going to ga ahead and change them out j/w what could possibly cause this?? Quote
digitaloutsider Posted August 23, 2005 Report Posted August 23, 2005 Using a platinum plug. Waste-spark systems eat through them, especially the pieces of shit known as Bosch plugs. Quote
GP1138 Posted August 23, 2005 Report Posted August 23, 2005 Using a platinum plug. Waste-spark systems eat through them, especially the pieces of shit known as Bosch plugs. He's right you know. Quote
Stevo Posted August 23, 2005 Report Posted August 23, 2005 Yeah Bosch is the worst thing to hit the 3.4 since oil pump drive seal replacement. Quote
Brian P Posted August 23, 2005 Report Posted August 23, 2005 Get the BOSCH shit out of there and go with Delco or in a pinch, autolite or champion Quote
gp90se Posted August 24, 2005 Report Posted August 24, 2005 Delcos or NGKs only in the 3.4 My plugs turned purple after running mystory oil in the motor, not sure i like that shit either. Quote
MoTox8410 Posted August 24, 2005 Author Report Posted August 24, 2005 My plugs turned purple after running mystory oil in the motor, not sure i like that shit either. mystory oil???? yeah i realized that about bosch about a week after i bought the plugs... are there o2 sensors bad as well??? are the rapidfire plugs good im gon' change them out tomarrow? what number are they??? Quote
19Cutlass94 Posted August 24, 2005 Report Posted August 24, 2005 I dont think you really need platnuim plugs. The regular Delco plugs are fine. But yes, those plugs are very good. Quote
Brian P Posted August 24, 2005 Report Posted August 24, 2005 Delcos or NGKs only in the 3.4 My plugs turned purple after running mystory oil in the motor, not sure i like that shit either. you probably are aware of this anyway, but I noticed NGK makes the Delco Iridiums for the 3100/3400 Quote
DaveFromColorado Posted August 24, 2005 Report Posted August 24, 2005 I run standard A/C Delco plugs in mine (cause I'm too cheap) and they work very well for me. on a side note ... Marvel Mystery Oil is just kerosene with a FEW (not many) detergents. --Dave. Quote
MoTox8410 Posted August 24, 2005 Author Report Posted August 24, 2005 were the original plugs platmium?? Quote
mfewtrail Posted August 24, 2005 Report Posted August 24, 2005 were the original plugs platmium?? The original DOHC plugs are just the standard AC Delcos(part # R42LTSM), they're not platinum. They're typically around $2 per plug. Quote
Calvin Posted August 30, 2005 Report Posted August 30, 2005 You don't need platinum plugs, they won't get you any more power, just more mileage between maintenance intervals. Since you actually work on your car, this obviously doesn't matter. Just get Delcos or Delco Rapidfires. They both work great. How great? Well, GM chose them to obtain optimum mileage, power, and durability for your car. I ponied up for Rapidfires, but anything Delco in the right heat range works. Quote
digitaloutsider Posted August 30, 2005 Report Posted August 30, 2005 RapidFires are platinum.. If you want a "performance" plug for waste spark ignition, Get NGK Iridium's (NGK makes AC Delco's, don't bother paying more for them). Quote
chadz34 Posted September 8, 2005 Report Posted September 8, 2005 While we are on the topic of plugs. I popped the hood on my Lumina and noticed that the front 3 wires are red....and they back 3 are black / gray. WHy the hell would Chevrolet put two colors of wires on the car? Quote
gp90se Posted September 8, 2005 Report Posted September 8, 2005 While we are on the topic of plugs. I popped the hood on my Lumina and noticed that the front 3 wires are red....and they back 3 are black / gray. WHy the hell would Chevrolet put two colors of wires on the car? lazy people doing 1/2 ass jobs when doing tuneups, go replace the rear plugs and wires as well as the fronts. Quote
digitaloutsider Posted September 8, 2005 Report Posted September 8, 2005 Actually, the plug wires I bought for the cutlass came that way. The front's are red, and the rears are black. A lot of the 3.4 wires I see are that way. Quote
chadz34 Posted September 8, 2005 Report Posted September 8, 2005 Cool. I thought my Z was messed. Quote
