SUPERDUTYD Posted August 23, 2005 Report Share Posted August 23, 2005 i found exhaust from a 2000 grand prix and want to put it on my 96 monte 3100. will it fit at all? will it fit easily using stock hangers? i am only going to use the mufflers and the exhaust pipe where it splits into 2. Quote Link to comment Share on other sites More sharing options...
jeremy Posted August 23, 2005 Report Share Posted August 23, 2005 I don't see that bolting up correctly. Quote Link to comment Share on other sites More sharing options...
Brian P Posted August 23, 2005 Report Share Posted August 23, 2005 It's very close if not exactly the same. I had a '03 up in the air at my job and it looked near identical to the older setup. The only spot where you'll probably have a problem is the downward angle you'll need on the tailpipes, but you could find a way to drop the mufflers down a little, that may work. Quote Link to comment Share on other sites More sharing options...
SUPERDUTYD Posted August 24, 2005 Author Report Share Posted August 24, 2005 thanks, i am going to try it. Quote Link to comment Share on other sites More sharing options...
jeremy Posted August 24, 2005 Report Share Posted August 24, 2005 let us know if it bolts up.....I always thought the 2G w-bodies were a lot wider then the 1, 1.5G so I didn't think there was a chance it would work, but I am curious as to the result. Be sure to get some pics of the fit either way though. Quote Link to comment Share on other sites More sharing options...
manitcor Posted August 24, 2005 Report Share Posted August 24, 2005 they are a bit wider and the exhaust will be too, but not so wide it shouldnt fit, though you may have to cut here and there to get it to line up Quote Link to comment Share on other sites More sharing options...
