1990lumina Posted August 19, 2005 Report Posted August 19, 2005 The below file is 10mb...so unfortunately 56k will have a hard time viewing the video, sorry about that. http://media.putfile.com/engine-movement-reverse-vibration After watching this video of my engine rocking back and forth, would you say this is excessive engine movement and/or some engine/tranny mounts are worn/broken?? When you are watching the video, keep in mind when the engine goes forward I believe I am shifting it into reverse (And if you have been following my posts you'll know there is quite a audiable *clunk* when I shift into reverse. Also, when I put the camera on the dash, I didn't want it to come out like that, I was trying to put you in my car, but the camera was mounted to anything so it just tipped back and forth. Anyway, is this excessive movement of the engine, or not really?? I've checked the vacuum modulator on my tranny, and it appears to be fine. - Jeff L. Quote
gp90se Posted August 19, 2005 Report Posted August 19, 2005 Looks like the motor mount in the cradle is shot, mine was doin pretty much the same shit, plus vibrations at high speeds (100+), welded in a solid mount (piece of pipe) and ta da, all set. Quote
1990lumina Posted August 19, 2005 Author Report Posted August 19, 2005 Well I've noticed when I kicked it down at 65mph and it hits second gear, there is a *thunk*...I thought fuck now what's wrong with the tranny (I thought it had slipped)...but now I believe my problems (most of them) to be worn out mounts....I'm just not smart enough to know which ones. Quote
gp90se Posted August 19, 2005 Report Posted August 19, 2005 theres 4 mounts on a 3.1, 2 dogbone, motormount on the bottom front right of the cradle and the tranny mount behind the drivers side tire. the lower mount is oil filled and they end up leaking. go investiage Quote
Robby1870 Posted August 19, 2005 Report Posted August 19, 2005 When I noticed my bad front rubber dogbone bushings being shot on my old 92 GP, you could physically see the dry-rotting. Like just take one of the dogbones off and look at the bushing...if its cracked, its bad. Usually the driver's side one will crack first b/c its right by the upper radiator hose and gets more heat. To alleviate the problem with the upper mounts, I drilled the engine side of the mount hole out, making it a constant diameter hole instead of having the taper in the middle. Then, I bought two poly-urethane 1 3/4" bushings for a fiero and put those in. I orginally did this on both sides of each mount, but I got too much vibration back through the car for my liking. So, I redrilled a second set, just drilling out the engine side of each mount and installed the bushings. My engine doesnt move at all and the car doesnt vibrate at all. Perfect. Quote
chadz34 Posted August 19, 2005 Report Posted August 19, 2005 That is huge engine movement. I bet it's just the bottom 2 mounts. Quote
sonyman87 Posted August 19, 2005 Report Posted August 19, 2005 That is huge engine movement. I bet it's just the bottom 2 mounts. i say leave the bottom 2 alone and get 2 poly dogbones Quote
gp90se Posted August 19, 2005 Report Posted August 19, 2005 my regal needed dogbones bad when I got it (bushings were 1/2 out) and it didnt move that much, ill bet its the bottom motor mount Quote
Euro Posted August 19, 2005 Report Posted August 19, 2005 yeah the bottom mount(S) would be my guess....and i thought my engine moved lol Quote
manitcor Posted August 19, 2005 Report Posted August 19, 2005 as old as your car is I would say the bottom mounts are most likely shot. You have an engine mount on the passeger side almost diretly below the crank pulley im not entirely sure wehre the trans mount is, I think its directly oppsite the engine mount under the bell housing. Your dog bone mounts may also be shot and you can either replace them with stock or poly. One note on poly is that they dont absorb vibration as much and transmit more of that vibration into the body so you will feel the engine alot more. If that doenst bother you I saw go for the poly as it will make your shifts more firm and true as well as allow more power to the ground rather than get lost in the virbration. Once you get all your monts replaced and esp if you go for poly dogbones your engine should hardly move at all. Quote
Stevo Posted August 19, 2005 Report Posted August 19, 2005 Are'nt the bottom mounts a 2 piece bolt up design that floats in a rubber block??? Quote
J Posted August 19, 2005 Report Posted August 19, 2005 yep looks like mine, i'll be doing the mounts this winter. BTW that fucker is clean as hell! Quote
manitcor Posted August 19, 2005 Report Posted August 19, 2005 Are'nt the bottom mounts a 2 piece bolt up design that floats in a rubber block??? im not sure about the other w-bodies but mine is like that, its a big rubber block that sits in the cradle and has 2 bolts on a metal bracket that hold it to the eninge and another set to hold the mount in the cradle. Quote
z34_nut Posted August 19, 2005 Report Posted August 19, 2005 Hell, with that much movement, I wouldn't feel safe..reminds me of GP1138's car... Quote
digitaloutsider Posted August 19, 2005 Report Posted August 19, 2005 Before I changed my lower mount and dogbone, rocking the car by hand would make the engine move through the whole damn compartment. Definitely looks like your lower one is shot though. Quote
GP1138 Posted August 19, 2005 Report Posted August 19, 2005 Hell, with that much movement, I wouldn't feel safe..reminds me of GP1138's car... I KNEW that was gonna come up... :oops: Quote
1990lumina Posted August 19, 2005 Author Report Posted August 19, 2005 Okay, so it seems I'll be checking out the lower mounts. SOmeone said they are oil filled or something. What exactly should I look for as far as deteroration??? I'm knew to this type of stuff so I wouldn't know exactly what a bad mount would look like. Also, the top dog bones if I grab them I can slightly move them up and down with my hands, so they are fairly worn out to I would guess. Son of a bitch lol...how much would the new mounts be (the lower ones)??? And what's this about GP1138s car??? Quote
manitcor Posted August 19, 2005 Report Posted August 19, 2005 Okay, so it seems I'll be checking out the lower mounts. SOmeone said they are oil filled or something. What exactly should I look for as far as deteroration??? I'm knew to this type of stuff so I wouldn't know exactly what a bad mount would look like. Also, the top dog bones if I grab them I can slightly move them up and down with my hands, so they are fairly worn out to I would guess. Son of a bitch lol...how much would the new mounts be (the lower ones)??? And what's this about GP1138s car??? All the mounts are urethane rubber. I paid a little under $90 a piece for the lower mounts. A set of poly inserts for the dogbones run about $60. I think stock replacement for the dogbones are like $80 from a stealership. Unfortunatly I think your stuck with stealership parts too. Theres not aftermarket ones that I know of and this is something your dont really want to steal of a junker. The good news is once all done they will last you for another 100k or more. Quote
GP1138 Posted August 19, 2005 Report Posted August 19, 2005 My old Grand Prix had the wonderful cradle bolt problem and broke one of them in the beginning of '04. I then proceeded to drive to Michigan on three cradle bolts. The engine was free to move about the underhood bay. God knows how the hell I got out there and back no problems. I miss that car, though. R.I.P. :bawl: Quote
Robby1870 Posted August 19, 2005 Report Posted August 19, 2005 Okay, so it seems I'll be checking out the lower mounts. SOmeone said they are oil filled or something. What exactly should I look for as far as deteroration??? I'm knew to this type of stuff so I wouldn't know exactly what a bad mount would look like. Also, the top dog bones if I grab them I can slightly move them up and down with my hands, so they are fairly worn out to I would guess. Son of a bitch lol...how much would the new mounts be (the lower ones)??? And what's this about GP1138s car??? All the mounts are urethane rubber. I paid a little under $90 a piece for the lower mounts. A set of poly inserts for the dogbones run about $60. I think stock replacement for the dogbones are like $80 from a stealership. Unfortunatly I think your stuck with stealership parts too. Theres not aftermarket ones that I know of and this is something your dont really want to steal of a junker. The good news is once all done they will last you for another 100k or more. I found my poly bushings for ~$18/pair Quote
manitcor Posted August 19, 2005 Report Posted August 19, 2005 Okay, so it seems I'll be checking out the lower mounts. SOmeone said they are oil filled or something. What exactly should I look for as far as deteroration??? I'm knew to this type of stuff so I wouldn't know exactly what a bad mount would look like. Also, the top dog bones if I grab them I can slightly move them up and down with my hands, so they are fairly worn out to I would guess. Son of a bitch lol...how much would the new mounts be (the lower ones)??? And what's this about GP1138s car??? All the mounts are urethane rubber. I paid a little under $90 a piece for the lower mounts. A set of poly inserts for the dogbones run about $60. I think stock replacement for the dogbones are like $80 from a stealership. Unfortunatly I think your stuck with stealership parts too. Theres not aftermarket ones that I know of and this is something your dont really want to steal of a junker. The good news is once all done they will last you for another 100k or more. I found my poly bushings for ~$18/pair luky, you gen 1s have round ones on both ends dont you? The funky square ones on the 1.5s run $56. I wonder if the round end is still the same size for both styles though. I still have stock urethane on that end. hmmmm Quote
gp90se Posted August 20, 2005 Report Posted August 20, 2005 That was me who said they were oil filled, its like a grease, when i jacked up my motor you could see it all over the cup where the mount goes. Quote
manitcor Posted August 20, 2005 Report Posted August 20, 2005 mine had that too, it was from a blown headgasket and the oil mixing with dirt and junk as it dripped down Quote
Robby1870 Posted August 20, 2005 Report Posted August 20, 2005 Okay, so it seems I'll be checking out the lower mounts. SOmeone said they are oil filled or something. What exactly should I look for as far as deteroration??? I'm knew to this type of stuff so I wouldn't know exactly what a bad mount would look like. Also, the top dog bones if I grab them I can slightly move them up and down with my hands, so they are fairly worn out to I would guess. Son of a bitch lol...how much would the new mounts be (the lower ones)??? And what's this about GP1138s car??? All the mounts are urethane rubber. I paid a little under $90 a piece for the lower mounts. A set of poly inserts for the dogbones run about $60. I think stock replacement for the dogbones are like $80 from a stealership. Unfortunatly I think your stuck with stealership parts too. Theres not aftermarket ones that I know of and this is something your dont really want to steal of a junker. The good news is once all done they will last you for another 100k or more. I found my poly bushings for ~$18/pair luky, you gen 1s have round ones on both ends dont you? The funky square ones on the 1.5s run $56. I wonder if the round end is still the same size for both styles though. I still have stock urethane on that end. hmmmm The 3100s are a different diameter bushing. To drill the 3.1L doggones out to work with a fiero poly-U bushing, you need a 1 3/4 hole saw and lots of 3 in 1 oil Quote
Grand Moff Joseph Posted August 23, 2005 Report Posted August 23, 2005 Yeah, way too much movement there. I'd start with the top dogbones, and see how much that helps. If there is still excessive movement, go for the bottom ones. BTW, where can you get a set of bottom mounts, and can they be changed without going to a mechanic to do it? Quote
