sonyman87 Posted August 18, 2005 Report Posted August 18, 2005 replaced my Interstate battery and WOW. the car came back to life. im amazed how easy the car turns over, and how everything seems to work like its new. and for some reason my Transmission SHIFTS correctly again1! OMGWTFBBQ. i wonder if it had anything to do with the "e" in 4t60e. finnaly got enough juice to select the next gear. Quote
1990lumina Posted August 18, 2005 Report Posted August 18, 2005 Unless your alternator is "putting out" the new battery *shouldn't* have an effect on the shifting of the tranny, but who knows, wierder things have happened lol.. Good to hear she's shifting and turing over better now I'm planning on replacing my POS AC delco with a Optima before winter because last year that piece of crap which is only 2 years old barely can turn over the engine when it's cold lol... Good, good to hear shes running good Quote
sonyman87 Posted August 18, 2005 Author Report Posted August 18, 2005 yeah i have no idea why my car was doing what it was and not its not.. alt tested at 14.03 volts for a pass Quote
manitcor Posted August 18, 2005 Report Posted August 18, 2005 you may be putting out 14 volts at the alternator but the wiring from the alt to the power block may be worn and causing a drop in voltage. May want to check that out ;-) Quote
john99gtp Posted August 19, 2005 Report Posted August 19, 2005 also, it depends how much load was put on the alternator for the test too i can get 14v from a 14v battery, but that doesnt mean it can do 14v at 10Amps (or however many amps our alts are) Quote
EurosportZ34 Posted August 19, 2005 Report Posted August 19, 2005 so what kind of battery did you replace your Interstate battery with? Quote
maybe2fast Posted August 19, 2005 Report Posted August 19, 2005 I wonder if you giggled a harness and it is acting right again... Quote
sonyman87 Posted August 19, 2005 Author Report Posted August 19, 2005 i replaced it with an overpriced Haritage i didn't touch anything under the hood.. the alt test was with the poor condition battery in at 156 amps.. not a ture ready but diffinatly putting power down. the battery was almost 3 years old and it was leaking battery acid in the battery box. it just wasnt putting out the ampers. i do have to say i jumped the gun on saying my trany shifts all the time good now. it did it all day good and now its back to the wwwwaaahahhh ba ba ba baawwwww shit again. Quote
BurneroftheRice Posted August 19, 2005 Report Posted August 19, 2005 yeah its really wierd the stuff that happens when your battery or alternator go out. So i guess if you get a new battery or alternator wierd things might run better Quote
Psych0matt Posted August 19, 2005 Report Posted August 19, 2005 I wonder if you giggled a harness and it is acting right again... you mean jiggled? Unless you told it a joke or something Quote
