spectre5 Posted August 18, 2005 Report Posted August 18, 2005 hey guys, the cooling fan(s) have gone on my car. Specifically the passenger side fan doesnt work at all, and the driver side works w/ AC only, but it might be that way permanently. Anyway, replaced passenger side fan motor, and checked and double checked fuse relays under the hood. Any ideas, solutions, comments would be appreciated Quote
cutlassdude96 Posted August 19, 2005 Report Posted August 19, 2005 turn the ac on max with the fan on high, or if your car is a 93 or older, jump the ADL conector Quote
spectre5 Posted August 19, 2005 Author Report Posted August 19, 2005 Well I use the AC to keep it cool now, but I need a more permanent solution. I will try the AD Connector. But others are welcome to comment as well. Quote
GnatGoSplat Posted August 19, 2005 Report Posted August 19, 2005 Sounds like you have a bad coolant temp sensor or a bad ECM. Quote
