Darkness Posted August 17, 2005 Report Share Posted August 17, 2005 Well, I clocked 253K+ miles, and I am starting to wonder if I should change out my converter for a flow, and new mufflers while I am at it. I haven't crawled under the car yet. Are the cats the kind with the oval intake and rectangular flange, or are they round? I will probably go with a Catco universal cat (2.5", right?) and they are round. Just wondering if I need to cut some pipe, too. Also, I don't think there is a tube sticking out of the original cat. Just want to make sure before I start spending money. Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted August 17, 2005 Report Share Posted August 17, 2005 well, ur car might be old enough u dont need a cat, check ur states laws to see if its required after so and so years Quote Link to comment Share on other sites More sharing options...
Darkness Posted August 18, 2005 Author Report Share Posted August 18, 2005 Ohio is 25 years. Got a ways to go yet. Quote Link to comment Share on other sites More sharing options...
TGPilot Posted August 18, 2005 Report Share Posted August 18, 2005 I have never heard of a state that allows factory installed cat converters to be removed. 8) Quote Link to comment Share on other sites More sharing options...
Guest ChiefWiggum Posted August 18, 2005 Report Share Posted August 18, 2005 If your cat's not clogged, there's not really a need to replace it. Although yours could be with that many miles. I would do 3 simple tests: 1: Listen to the exhaust. Does it still sound kinda of loud like you remember it sounding in the past? If not, it could be clogged. 2: Smell the exhaust. Does it stink like gas? (Of course if it does, that could be another problem) If it does, could be clogged or burned out. 3: Put your hand over the tailpipes. Does it feel like you can feel individual pulses or does if feel more like a slow triclke of heat? Should feel more like pulses or it could be clogged. If you have none of these problems, I wouldn't touch it. As for emissions, I've always heard that the cut off point is 1978 becaue it was the first year for emissions control and cats. It's not a static # like 20 or 25 years old. Quote Link to comment Share on other sites More sharing options...
Darkness Posted August 18, 2005 Author Report Share Posted August 18, 2005 I'll try those out, chief. For Ohio counties there is a 25 year cut-off for the E-check, but technically, you cannot go without a cat on a car originally equipped with one, though you can replace it with a different type. Cat check is usually done by visual inspection, if at all. Quote Link to comment Share on other sites More sharing options...
