technical service bullitin
I just read a service bulitan about the PROM in our ecms going bad. In the TSB it said that probles associated with this is Long Cranks, Idle, Decel Surge. Diagnosis was to replace PROM. If you have been following up on my problems, those are some of the things that are wrong with my car. I was the prom like a chip in the ECM? if so, can I just buy a performance chip?
Doubtful, I haven't monkeyed with a 93 ECM yet, but I think it's the same as the 89, and you put your PROM on top of the chip, then insert the chip. So you'll still need your PROM. Could be wrong, anyone???
