Is this normal for HUD?
Well, sometimes, not every time, like, usually, if the brake hasnt been pressed within like, 1 minute or so, but if its before that or so, it wont do this, when u press the brake, it will make both the blinker arrows light up on the HUD but not the cluster, but not while the brakes on the whole time, just like, fast for a second, is kinda annoying, what would cause this
No its not normal.
But in those years, the brake light is routed thru the turn signal switch in the column, so that kind of gives you a spot to start.
