shuttering/loud vibration noise/doesnt want to go z-34?
My z-24 just doesnt seem to want to go. when i would give it a little gas going down the road, it would be at like 4 grand and the car feels like its barely moving.when it is idleing in gear, it makes a horrid vibration noise. The EGR valve is bad. Could this be the problem? or something else maybe? timing?
need a little more detail on which motor, but start with the obvious, make sure all 6 cylinders are firing, plug wires are all on and in good shap, blah blah blah. It could be the transmission failing, could be a number of things. cant take a small video of it idling can ya?
deffinatly need a list of repairs and replaced equipment in the last 10k miles or better.
fouled plugs will cause the o2 sensor to fail only exagerating the condition of a buck and jerk. lower RPMs will seem useless b/c the ignition banks dont have enough juice to jump the massive corroded gaps over warnout stock wires.
we definatly need more descriptiong. like does it happen when its hot or cold. does it do it at certin rpms. up hills down hills. at a stop. in drive. awnser those and we could help you get somewhere.
