webbs Posted August 4, 2005 Report Posted August 4, 2005 ok i just got a brand new rockford fosgate amp #3001 i got this amp becaus ei have connections at best buy and i got it for 20 dollars my question is what would be the best subs and box for this amp and id like to make my own box if some1 could design me one Quote
jeremy Posted August 4, 2005 Report Posted August 4, 2005 i got this amp becaus ei have connections at best buy and i got it for 20 dollars did he steal it? I know BB employees don't get discounts like that Quote
19Cutlass94 Posted August 4, 2005 Report Posted August 4, 2005 whater type of subs you like, its more personal perference than anything, least I think, plus depends on how much dough you've got to spend. Quote
webbs Posted August 4, 2005 Author Report Posted August 4, 2005 no i didnt steal it and yeah bb employees get 50% off idk really how i got it for so cheap i have like 300 to spend on subs and a box if i make isnt that expensive and i just would like to get some ideas than pick which ones than have some1 design me a ported box Quote
Puggsley456 Posted August 4, 2005 Report Posted August 4, 2005 no i didnt steal it and yeah bb employees get 50% off idk really how i got it for so cheap i have like 300 to spend on subs and a box if i make isnt that expensive and i just would like to get some ideas than pick which ones than have some1 design me a ported box I can heelp you with the box designs but you need to tell me which ones you chose before I start, and also how much space you have and what you're looking for SQ/SPL wise. If you do the box yourself.....it should only cost arround $40-50....So lets guesstimate that thje sub you are looking for has to be arround the 200-250 mark. What size of subwoofer do you want? 10, 12 or 15? You can get a ed 16Kv.2 for $135 Its the small brother to the one I use and I love it! http://www.edesignaudio.com/product.php?cid=1&pid=5&cur=USD Or if you are looking for a nice quality single 12 I recommend the Image Dymanics 12" IDQ. http://www.cardomain.com/item/IDSIDQ12D4V2 Just remember that what ever sub you chose, when wired up it needs to be able to offer a 2 ohm impedance to get the most out of that amp. So this means for one sub you need a Dual 4 ohm voice coil configuration. Quote
webbs Posted August 5, 2005 Author Report Posted August 5, 2005 how do these look? there really cheap http://www.cardomain.com/item/ABNDUB100 Quote
webbs Posted August 5, 2005 Author Report Posted August 5, 2005 2 of them 83 bucks i think im gonna get them can u design me a box PUGGSLEY?? Quote
Puggsley456 Posted August 5, 2005 Report Posted August 5, 2005 I wouldnt touch them with a ten foot pole.........Your gonna get what you pay for. Quote
Puggsley456 Posted August 5, 2005 Report Posted August 5, 2005 Oh and as per Audiobahn....they require 1.5 cubic feet each tuned to 37HZ....DO you have room for a 3+ Cubic foot box? http://www.audiobahn.com/tech/2004/boxParams/DUB200.pdf Quote
webbs Posted August 5, 2005 Author Report Posted August 5, 2005 is there anything besides those image dymanics because thoe are factory backorder so i could be waiting forever Quote
Puggsley456 Posted August 5, 2005 Report Posted August 5, 2005 is there anything besides those image dymanics because thoe are factory backorder so i could be waiting forever Do you want one sub or two? Theres a wicked deal on Kicker Comps right now....buy one get one free! http://www.cardomain.com/item/KIC05C1242PAK Quote
webbs Posted August 6, 2005 Author Report Posted August 6, 2005 yeah thats a hell of a deal those will work good with that amp? if so just design me a box for 2 of them and than uk the clearanc in a 95 CS since u have a 94 and thanx for all ur help i would be very lost wiothout u Quote
Puggsley456 Posted August 6, 2005 Report Posted August 6, 2005 yeah thats a hell of a deal those will work good with that amp? if so just design me a box for 2 of them and than uk the clearanc in a 95 CS since u have a 94 and thanx for all ur help i would be very lost wiothout u No problem... I found this box which should work perfectlly....when putting it inot the trunk....aim the subs facing up towards the sky, place the box into the trunk in that possition and then rotate the box so that the subs face the rear.....That was the only way I could get my dual 12 box in the trunk and it was the same as that one. http://www.icixsound.com/vb/icixnation/images/38_61.gif Quote
Puggsley456 Posted August 6, 2005 Report Posted August 6, 2005 Your amp does 300rms at 2 ohm. When those subs are wired together like this: It will be a perfec match for those two Kickers(rated at 150rms each).......And Kicker recommends a ported enclosure of 1.75cubic feet each.....But that design is 1.5cubic feet per sub. This will give you a bit more leeway, because when you decrease the box size you gain a little bit more in the power handling department. Quote
