DrRodey Posted August 4, 2005 Report Posted August 4, 2005 I"m working on converting my 92GTP from R-12 to 134A, and absolutely can't find the connectors on the lines that need to be replaced. Anyone done it that can help me with some directions on where to find these two connectors? Thanks. Dan Quote
Darkness Posted August 4, 2005 Report Posted August 4, 2005 On my TGP the high pressure connector was located sort of under the wind washer tank near the battery. The low pressure connector is located on a tube that runs under the high pressure one. The high pressure connector sticks straight up, and the low pressure connector sort of points to the engine itself. If you see the high pressure connector, the low pressure one is about 2 inches away. Quote
GnatGoSplat Posted August 4, 2005 Report Posted August 4, 2005 Look under the airbox. Only GM would hide those fittings. Quote
fastbird232 Posted August 4, 2005 Report Posted August 4, 2005 Yeah, I had to disconnect the airbox completely. HOWEVER, since you need to have the motor on while you fill it, don't diconnect the MAF, because the damn thing won't stay running if you do. Just lay it on the intake manifold or something. Quote
DrRodey Posted August 4, 2005 Author Report Posted August 4, 2005 I should have known GM would try and hide everything. They just can't make one dang thing easy to work on, well at least until you get something ripped 3/4 apart. Thanks y'all. Dan. Quote
GP1138 Posted August 4, 2005 Report Posted August 4, 2005 Just wait till you get the fitting installed and your airbox won't fit properly again. BWAHAHAHAH Unless it's different for the 3.4. Quote
Darkness Posted August 4, 2005 Report Posted August 4, 2005 On the TGP the airbox is right behind the radiator, so I didn't have to worry about that. But, I couldn't get the darn filler hose on the low pressure valve without wrestling with the turbo blanket. And damnit, I had AC for about 24 hours, now nothing, and I used that EZ Chill stuff that is supposed to have oil, conditioners and leak sealant in it. Quote
DrRodey Posted August 5, 2005 Author Report Posted August 5, 2005 I've got a K&N Cone so refitting the air box won't be a problem.. it's already gone. I just feel stupid as a 30 cent piece on dollar night, I didn't even have to remove the air filter, jsut push it aside a little. Well Got everything changed over, put in the first can and as i'm hooking the second can onto hte fill hose, i'm just watching the presure drop, so time to go find a leak i guess. Wish me luck Dan. Quote
GnatGoSplat Posted August 5, 2005 Report Posted August 5, 2005 Compressor shaft seal is a common leak location on the V5 compressors. Quote
