Odd idle
95 Cutlass Drop Top
I just really started to notice this it seems to have gotton worse. I have a pretty rough idle, it idles to the point where it seems to cut off but doesn't. Also somethimes when driving down the highway when you get off the gas, the rpms drop down for like half a second then its back normal. Like if the rpms are around 2500 it'll drop down around 1700-2000 then right back up to normal. What could be causing this?
Adjust the TPS sensor maybe, had similar problem with an ex-car. Is your car a 3100 or 3.4?
O, dont really know much then. Try fuel filter, check for pressure in the rails, and spark.
our TPS's are non adjustable
