setting up my sub/amp
its hokey but does this look right??
would that be where the Line level converter (LLC) :wink: should go or would i put it after the stock amp or would it matter, is there a benifit either way
FWIW i will try this with the rear speakers connected first because the factory stereo rocks i just want more bass
also - Remote wire for sub amp - can i splice from the harness or would it be better to run a separate wire with maybe a toggle to turn sub on and off
i am not changing the head unit i want to keep it stock i am only adding a sub
i dont use crap wires still have some monster/pg/stinger shit laying around to use
From what I can tell that looks about right.....But I noticed you're missing the ground from the sub amp. How does the signal get from the head unit to the factory amp? Via speaker wire?
yup. i pretty much worked through this with him on yahoo messenger.
Ground... :shock: :lol: :lol: forgot a line oops
