97regalGS Posted August 3, 2005 Report Posted August 3, 2005 anyone got the instructions to program a new keyless remote? i bought one of eBay and while it came with instructions, the instructions ask to remove the "MALL PGM' fuse. I can't find a fuse with such a label. Quote
GP1138 Posted August 3, 2005 Report Posted August 3, 2005 I couldn't find anything on the 1997 Regal, but according to GM Service Information, here are the 1998 instructions. Give 'em a try! Transmitter Programming Method 1-No Tools Required In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed. Important * Once entering this procedure, programming the first transmitter erases all previous transmitters. You must program all transmitters. * Program one vehicle at a time. One transmitter could be programmed into other vehicles that are also on program mode in close proximity. 1. Sit in the driver's seat. 2. Remove the ignition key from the ignition lock cylinder. 3. Close all vehicle doors. 4. Press and hold unlock on the door lock switch. 5. While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder. 6. Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure. 7. Release the door lock switch. You will hear three chimes. This chime feedback indicates that transmitter programming is active. 8. Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for 12 seconds. You will hear two chimes. This chime feedback indicates that the transmitter has been programmed successfully. 9. Repeat step 8 for the rest of the transmitters (for a total of 4 transmitters). 10. Exit this procedure by removing the ignition key from the ignition lock cylinder. Quote
97regalGS Posted August 3, 2005 Author Report Posted August 3, 2005 well, it took a couple of tries, but those instructions worked. tx for the info as they were noticeably different than the fuse removal scenario! thanks again. Quote
jeremy Posted August 3, 2005 Report Posted August 3, 2005 those instructions are the ones that are normally used for 2G w-bodies, glad to hear they worked for you Quote
jeremy Posted August 3, 2005 Report Posted August 3, 2005 The '97 Regal is a 2G W-Body! ........i know........I was stating that I wasn't surprised they worked Quote
GP1138 Posted August 3, 2005 Report Posted August 3, 2005 The '97 Regal is a 2G W-Body! ........i know........I was stating that I wasn't surprised they worked Ahh.. gotcha. Quote
