Exhaust smells horrible
After running my car for a lil bit, you get out and it smells absolutley horrible. It's smelled bad since I got it, but it's nowhere near as bad as the very first time it started. What would cause this problem? I can't think of anything to describle the smell.. one of my friends got out of the car once and said it smelled like ass... that seems to be the best description so far :lol:
Bad Catalytic Convertor, that's a telltale sign. Rotten eggs?
After awhile of driving, look under the car and see if the Cat is glowing.
If indeed the Cat is bad, find out what did it, something's not tuned on your car, bad sensor, something. They don't just go bad, they are murdered.
Not always a bad cat... it could be a high sulfur content in the gas you purchased for your car. Common mistake.
If you have bad spark you could also be dumping unburned fuel in the exhaust. It happened to me and it smelled terrible. I'd check the plugs, wires, coil packs and icm.
Guest TurboSedan
high mileage murdered mine :)
I was just gonna look up this problem, and what are the odds of finding it. And I really like the first descreption on the smell. Mine was horrible yesterday, it was hot outside, and I picked up my friend, and she says, did some one take a shit in your trunk?? I checked it out, and it was coming from the exhaust, and actually it smelled like everything mentioned so far, ass, rotten eggs, sulfur... I put in $20 of gas just a day before, and it smelled horrible. I filled her up today fully, and I can't smell a thing, well other than the usual. So I'm guessing MonteCarloChick was right in my case, and if not, I know what the problem is anyways.
That happened once to me, when I lost a cylinder on the way home from work. All the plugs has a little bit of oil ash on them from buring a little oil I mean cmon she is what 11yrs old, anyways, I could smell the exhuast even when I stopped at a red light. I was just dumping unburned fuel in. when I replaced the one plugs, and cleaned the others, the smell went away. I doubt it could be the plugs making it smell that bad, but probably just unburned fuel.
