Guest Gp crazy Posted August 1, 2005 Report Share Posted August 1, 2005 Well, About a month ago my brother in-law bought his first w body for $100.He thought it was going to be cheap to fix it! Ha to his poor skills to fix anything He thought he was going to change the gas tank and use the old sender & pump. But that lasted 20 miles the car ran great then he had to pump the pedal to get it home? I took off the feed line had some psi. But then I told to turn the key on but no engine OK i should have had a shower of gas but got a drop in stead. out it came again doing the job twice sucks when you told him the first time to get new stuff! Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted August 1, 2005 Report Share Posted August 1, 2005 you really don't have to pull the fuel line off to check for pressure, as there is a schrader valve on the fuel rail for that. dropping the tank to replace the pump sucks. it was a nightmare the first time i did it, but the second time wasn't nearly as bad. i have to do it again soon...damn level sender i put in does the same thing as the last one (car runs out of gas with 1/2 tank on the gauge) Quote Link to comment Share on other sites More sharing options...
Guest Gp crazy Posted August 1, 2005 Report Share Posted August 1, 2005 i will havE do REPLACE THE PUMP ON my lumina also very soon it makes sound's i do not like ! Quote Link to comment Share on other sites More sharing options...
Hairdo12 Posted August 2, 2005 Report Share Posted August 2, 2005 Do newer cars have a cutout in the trunk so you can get to the pump without dropping the gas tank? Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted August 2, 2005 Report Share Posted August 2, 2005 Do newer cars have a cutout in the trunk so you can get to the pump without dropping the gas tank?Yep, the 2nd Generation W-Bodies do - right underneath the back seat's lower cushion... Quote Link to comment Share on other sites More sharing options...
