Tomorrow im going to pick up a 97 LQ1 to put into my 94 GTP
Thank you Jay for giving me his number, Im going to pick it up tomorrow at 11.00 AM.
Yes you can swap a 96-97 3.4 into a 94-95 car, but you will need to do the following.
First off, you will need the 96-97 exhaust manifolds and crossover. If possible, use your 94-95 intake manifolds, this will simplify things. If you can't, you can use the 97 intake manifolds, but it will require some work, so let me know whit year intakes you have. Most if not all of your harness connectors will plug into a sensor on the engine, you shouldn't have any left over if memory serves. The 96-97 alternator MIGHT be different than the 94-95s, I know the 91-93s are different. So you may need to use your 96 alt and mounting hardware, but it will plug right in. THe 96-97 exhaust manifolds will have ports for an AIR injection system. Your 95 car does not have this, therefore you will need to plug these off. There is a single, threaded hole in each manifold.
Other than this it should be a bolt in swap. THe only real difference in the two is the heads, cams, and timing belts, but those aren't an issue here.
was Aaron correct when he told me this (as far as all of you know?)
But he may of forgotten some small slight detail that someone else might notice, I dont mean to diss you or anything, you cant be too careful. Thanks for your help!
:wink: Wise, you are, young Jedi.
I agree, and there will be little stuff, but when it comes up, just post it up and we'll help out!
