jpfish Posted July 31, 2005 Report Posted July 31, 2005 I am trying to remove the front hub so i can put longer wheel studs in. I removed the caliper bracket and the four screws on the back side of the hub. I took off the 36mm axle nut and used a hub puller to start pulling, but the top wont come loose. I can pull the bottom side out and up, but the top of the hub is stuck. Anyone know what i am not doing? there are two little pin looking things that appear to be holding it in and on the other side some sort of sensor. I have no clue what to do? can anyone help, here are some pictures... Thanks. -jp Quote
jpfish Posted July 31, 2005 Author Report Posted July 31, 2005 thanks, i got em out. a little rage with a hammer worked for me. haha Quote
z34Phoenix Posted August 3, 2005 Report Posted August 3, 2005 ouch that was rusted good i just changed my hubs. careful with that hub puller... cause it can also endup being an axle puller :| Quote
