Psych0matt Posted July 29, 2005 Report Posted July 29, 2005 So, I'm thinking that if I do have to do a swap, I have two options. One is to find an L67 and try and tackle that, but I'm not sure I have the knowledge or experience to tackle something of that calibur. My other option would be to find another (94-95) LQ1 and do an even swap (and maybe making the extra effort for a 5 speed). The main thing I guess would be how much more work would the L67 be? I know I would have to redo all the wiring and tuning and stuff, but how much more physical work would there be involved. I'm just thinking that I would rather spend the same amount of money for an around 60K L67 than I would for an under 50k LQ1 (If I do this, I don't want an LQ1 with high miles, but an L67 wouldn't bother me to be a little higher) Any thoughts? I don't want this to become an "L67 vs. LQ1" thread, I'm just trying to figure out what would be best. I'm more or less planning ahead until I can actually find out what I did internally to the poor thing. Closest I can think is that the water pump went and I threw a rod or something. Quote
White93z34 Posted July 29, 2005 Report Posted July 29, 2005 you WILL spend more droping in a L67. Quote
Psych0matt Posted July 29, 2005 Author Report Posted July 29, 2005 well, I'm hoping to find an under 50K (if not lower) milage LQ1. A crate one would be nice, but I don't know if i could afford the $1100 or whatever it was :-/ I think a five speed is a must though Quote
5speedz34 Posted July 29, 2005 Report Posted July 29, 2005 Did you find out what happened to you motor? Is it forsure toasted? Quote
Psych0matt Posted July 29, 2005 Author Report Posted July 29, 2005 not sure yet, I havent been able to get home (parents house in michigan) to tear some things apart. Hmmm, if I had a car to get there I'm looking into buying a cheap 88-90 z24 for a winter beater/second car (since I really like those and miss my old one anyways) Quote
THe_DeTAiL3R Posted July 29, 2005 Report Posted July 29, 2005 3.4 get the heads and intakes ported before you drop it in and it should be nicely powerful. Quote
88Regal Limited Posted July 30, 2005 Report Posted July 30, 2005 stick with what works. PS: 90-94 is OBD1, 95 is OBD1.5, 96 up is OBD2. See a problem there? Quote
digitaloutsider Posted July 30, 2005 Report Posted July 30, 2005 No, 88-93 is OBD-I 94-95 is OBD-I.5 96+ is OBD-II And for what it's worth, it doesn't matter what OBD your car had stock. You're not using the factory wiring if you're moving to an L67 anyway. The only things you'd have a problem getting to work correctly (or at all) would be things like a HUD or DIC. Quote
88Regal Limited Posted July 31, 2005 Report Posted July 31, 2005 94 aint OBD1.5! (and about not mentioning the 88/89, I was talking in lumina years.... ):? Quote
Brian P Posted July 31, 2005 Report Posted July 31, 2005 yeah '94 is OBD "1.5" but regarding the 3.4 it's kind of not, however the 3.4 didn't use the flash-rom PCM until the OBD2 debut. Quote
94cutlatized Posted August 2, 2005 Report Posted August 2, 2005 94 is 1.5 for sure. Went to gm 2 days ago Quote
