havikx Posted July 29, 2005 Report Posted July 29, 2005 guages on the windshield, totally kewl and blah blah blah.. now..down to business..93 luminaZ34. i need a parts list and any other advice. if some1 could point me in the direction of an article... thanx. Quote
Guest Anonymous Posted July 29, 2005 Report Posted July 29, 2005 You will need: The HUD unit HUD Tray with cable HUD dimmer switch All wiring Best to use the early GP/Cutty ones. GP ones are easier to find, gearhead's website has the pinouts for the HUD and i beleive the lumina cluster pinouts are on here, as you will need to splic into the lumina cluster harness. Quote
Justin Posted July 29, 2005 Report Posted July 29, 2005 The GP one will be harder to work with since the factory bezel on the GP is rounded to match the contours of the GP dash. The Cutlass dash is flat like the Lumi, so you'd be better off looking for a CS unit in my opinion. Also, the earlier CS units with the metal grille on top have an integrated height adjuster so you don't have to mess with routing the cable for the vertical adjustment. That's what I'd look for personally. Quote
havikx Posted July 29, 2005 Author Report Posted July 29, 2005 what year cutty would this be from?.. cuz i know theres always that catch with HUD when certain years only work with certain cars. Quote
White93z34 Posted July 29, 2005 Report Posted July 29, 2005 the man who would know is crimsion fury z, he put it in his z34. Quote
GP1138 Posted July 29, 2005 Report Posted July 29, 2005 I know there's a Cutty HUD in a yard I go to often. If you want it, PM me. Quote
Guest Anonymous Posted July 29, 2005 Report Posted July 29, 2005 The GP one will be harder to work with since the factory bezel on the GP is rounded to match the contours of the GP dash. The Cutlass dash is flat like the Lumi, so you'd be better off looking for a CS unit in my opinion. Also, the earlier CS units with the metal grille on top have an integrated height adjuster so you don't have to mess with routing the cable for the vertical adjustment. That's what I'd look for personally. I'm talking about the 89-93 GP ones. Obviously, he can't slap one of the newer ones on there. an 89-93 GP HUD will work just as well in that application, except you would have to route the cable and attach the tray correctly, which is a PITA, unless he got one from a TGP. Quote
Crimson Fury Z Posted July 30, 2005 Report Posted July 30, 2005 mu hahaha! yes, i do know! mine is the 1st gen GP hud. and the cluster pinout is in the faq section. the hud pinouts for the hud harness and dimmer harness are on gearhead's site. i got the hud, dimmer/mirror adjuster and the metal bracket tray. i never have finished the mounting. i got about 1" tall foam/rubber mat piece that sits on top of the cluster then hud sits on the foam. feel free to hit my aim up or pm for any help. Quote
