kknobl Posted July 29, 2005 Report Posted July 29, 2005 All, I noticed that there is a plug of sorts that looks like it could be screwed in more. If you're looking at the engine bay, follow the intake up to where the EGR is. Just past that, right next to the plenum is a plug. I'm not sure what this is but it screws in, and some of the threading is exposed and has some light rust on it, as if it was screwed in at one point, but has since come loose. Any ideas on what this is and whether or not this could be causing the SES light to go on? I have a not so hot picture, but I can't figure out how to post it so if you want to see it, PM me with your e-mail address and I'll get it to you. Thanks, Kevin Quote
stockgp Posted July 29, 2005 Report Posted July 29, 2005 all i can think of right there is thetemp sensor. single wire? Quote
THe_DeTAiL3R Posted July 29, 2005 Report Posted July 29, 2005 If you don't wanna sign up at photobucket, you can go here: http://tinypic.com but you'll need to post JUST the LINK to the pic, since the IMG tags woun't work. Quote
kknobl Posted July 29, 2005 Author Report Posted July 29, 2005 all i can think of right there is thetemp sensor. single wire? Yes, single wire. Kevin Quote
kknobl Posted July 29, 2005 Author Report Posted July 29, 2005 http://i22.photobucket.com/albums/b314/kknobl/Picture_0021.jpg There's a link. Again, pic isn't so hot... Kevin Quote
GnatGoSplat Posted July 29, 2005 Report Posted July 29, 2005 Wow, you weren't kidding about the pic being not-so-hot!!! Anyway, I think the thing isn't a plug, but a vacuum fitting for the vacuum modulator on the tranny. If it were out too far, it would be a vacuum leak. I'm not at home so I can't check how far out that fitting is on my cars. I don't think it would cause any problem to see if it will turn in any more. Quote
Robby1870 Posted July 29, 2005 Report Posted July 29, 2005 Try tightening it up it wont hurt anything and check on the vacuum modulator end for cracks in the rubber boot Quote
93cuttysupreme Posted July 30, 2005 Report Posted July 30, 2005 I don't know what it is, but it looks the same. Quote
Supreme Cutlass Posted July 30, 2005 Report Posted July 30, 2005 Sorry about the hijack, but does that mean that I have a problem? I only have a little rubber cap on mine... Quote
DaveFromColorado Posted July 30, 2005 Report Posted July 30, 2005 ... I think I recognize that schrader valve! I don't think you've got a problem - IIRC that was one of the vacuum ports used for the auto trans. --Dave. Quote
digitaloutsider Posted July 30, 2005 Report Posted July 30, 2005 I've seen scrambled cable TV porn less blurry than that. Quote
kknobl Posted July 31, 2005 Author Report Posted July 31, 2005 Is this one any better? http://i22.photobucket.com/albums/b314/kknobl/000_0016.jpg Quote
93cuttysupreme Posted July 31, 2005 Report Posted July 31, 2005 much better. thats as far as it needs to go in. the red is thread sealant. Quote
Heza Posted July 31, 2005 Report Posted July 31, 2005 I've seen scrambled cable TV porn less blurry than that. Quote
