Rabbi Posted July 28, 2005 Report Posted July 28, 2005 im going to replace my IAC today since i think its causing my high idle problems since it may of gotten wet. Anyway autozone lists nothing under IAC , but they do have an IDLE AIR CONTROL VALVE this is the part i need correct? IAC Valve? Quote
john99gtp Posted July 29, 2005 Report Posted July 29, 2005 can someone explain to me how that works please i can read my IAC count, and its like 40 at idle, 100 cruise, 120-140 taking off wtf do those numbers mean? Quote
DaveFromColorado Posted July 30, 2005 Report Posted July 30, 2005 the IAC is actually a "Stepper motor" which will count the revolutions - the number assigned to the motor from the computer is an aproximate as to where the motor valve is actually sitting - it will allow you to read the count to see if it's functioning properly (IE: the number changes, and your idle will change) some scanners are smart enough to be able to control the stepper motor so you can actually test it either out of the engine still pluged into the harness - or in the engine, pluged into the harness with the engine running to see if it'll change the idle. --Dave. Quote
john99gtp Posted July 30, 2005 Report Posted July 30, 2005 yea, that maybe helped .05% i think ill google it, maybe that might help Quote
Aaron Posted July 30, 2005 Report Posted July 30, 2005 Well when the motor is open, it pulls a plunger back, so that it opens a passage. The engine can now pull air through this passage, thus raising the idle. When the IAC closes, it pushes the plunger to close the passage, therefore the engine can't get any air, and its idle drops. The count is how open or closed the plunger is. I hope this helps, I tried to keep it basic Quote
