Fuel Pump Question
Tonight I helped my friend put a new sender into his '97 GTP. My question is does the fuel pump pump at a constant rate or does it change with RPM's?
Guest TurboSedan
the fuel pump pumps at a constant rate; whatever it is rated at. engine RPMs have no direct effect on the fuel pump.
the FPR is what regulates the pressure. excess fuel goes back to the tank via return line.
