gear reduction starter
what w's had them? what's the diff between a regular starter and a gear reduction starter? i think i heard 97+ gps had them. is that the3100 gps, or 3800? if 3800, would that starter fit a 60*?
The 3100's had them also. Basically, they are smaller in size, and from what I understand, work better on higher compression engines.
just lower weight and they are smaller too, I belive. Ive heard good things about them
And the fact that they are a gear reduction starter :roll:
I put a starter off a 99 Malibu with a 3100 into my car and it was the smallest starter I could find that was listed for a 3100 at the parts store. Basically we looked at about 10 different starters and this one was the lightest and smallest.
Cranks my motor alot easier (10:1 compression FWIW).
I'd assume it makes the car start quicker. My 3100 has always started (even the first turn of the key after the intake swap!! :shock: ) within a half a second of turning the key. As opposed to my 2.8 which sometimes took 2 seconds.
the 3.1 starter is a beast at 9 lbs
Only 9 lbs? Holy crap I must be a weakling. I thought that bitch weighed 25 lbs.
Anyway, I'll definitely try to get a 3100 starter next time I need one.
Why is the Malibu starter the smallest? I thought they would only use 1 style of gear reduction starter.
I thought that was obvious given the title of the thread....way to contribute
I havent done a starter in like 5 years, but I coulda sworn it was more than 9lbs....Id say like 15 or so.
My stock one for the 3.4 is a heavy motherfucker thats all I can say. Now that I think about it I bet it's about 25-30 lbs. I've got a spare one I could wiegh in the garage, if someone wants me to.
About the different starters I thought the same thing. We looked up about 10 different starters for N-bodies and W-bodies and that was the lightest and smallest I could find.
My car still takes a few cranks, but I think thats because of the battery in the trunk and the high compression.
How do they differ? Were the other starters you compared it to also the gear reduction type?
Also, Do you still use the same amount of shims when changing between a 3.1 and 3x00 starter, or are the newer ones designed shimless?
It was wierd some weren't and some where. It seemed like GM haphazardly put them in different cars for different years.
I thought it was all 3100's that had the different starters but I guess it was the later ones.
It seemed like the bigger ones weren't gear reduction but the smaller ones were.
Yeah, I do think earlier 3100's got the regular big starter.
Even among the gear reduction ones, some were different sizes?
Honestly I can't remember that well, but I want to say yes.
Like I said I just got the smallest one I could find.
Also it seems like maybe all the 60* motors went to the smaller starter around this time(late 90's)
Yeah...I wanna say is was like 97
no way one of those starters weighs less than 8 lbs...even race starters don't wiegh less than 7.
Not sure if my 3100 has that starter since its a 94
my old 3.1 starter weighs 14 lbs. and thanks for the info guys. i think i've got what i wanted out of this thread. no wall i need to do is find a car that has one
