Oxygen Sensor Connector
Wife's 3.4 is throwing a code 1-3 Open circuit for O2 Sensor. Where the hell is the connector at? I looked in that inch of space behind the plenum and can't seem to find it.
if its anything like the 3.1MPFI's o2 sensor, then its on the rear exhaust manifold right in the center....it might be best to jack the car up if you have access to a lift to change it if you're not removing the plenum.....I'm sure one of the DOHC guys will tell ya exactly how to do it....hope this helps in some way and good luck!
the sensor is on the pipe after the rear manifold and crossover pipe come together. you can only see it from the bottom. its a pretty tight fit.
Yea, I know where the sensor is, I'm taliking about where the connector is at in the wire cluster. That's where I can't find the pain in the ass.
It sort of dangles back there behind the plenum. At least that's how it is on my '94.
