THETANK Posted July 22, 2005 Report Posted July 22, 2005 I just pulled the spark plug boots off of the plugs (the front ones only). There is a ton of oil in the area where the spark plug sits (on 2 of the 3 plugs). I did not remove the plug just the boot and oil was dripping off of it. I have the 3.4 L engine. what is causing this and how do I fix it? Quote
5speedz34 Posted July 22, 2005 Report Posted July 22, 2005 Valve cover gaskets, the o-rings around the spark plug holes leak it down into the bore. Get new gaskets and you'll be set. Quote
White93z34 Posted July 23, 2005 Report Posted July 23, 2005 also i could imagine its caused by the fact that the oil fill cap is right there, i know if i'm not careful filling my oil it will go down there if i spill any. Quote
