Sunroof Chattering (more like rubbing)
Ok, when i put my sunroof to the vent position, the front part makes a chattering noise, i lubed the tracks in hope it might help, but it didnt, is there somthing im missing to lube or what? oh i might of accedently got some amroall on the velvet stuff around the edge of the sunroof, that wouldnt cause it would it
My sunroof was making an awful chattering noise. When I took the cover out I noticed that some of the tabs that keep it in its tracks were broken off. But, after fixing the liner and reinstalling it, things are quiet again. Maybe mine was caused by something loose that I tightened again after reinstalling. Might be the plastic channel guides that attach to the glass portion. Dang it.. not sure how to describe those things...
ok i shouldnt even say its chattering, it just rubs the front part when u "pop" it open or called the Vent position, its annoying, the velevty strip is what rubs against the paint/ sunroof frame aread, and it makes a chattering noise, i guess i used some bad terminalogy here, cause u prolly think its skippin off its track
Maybe you need to adjust the glass a hair. The glass actually slides back and forth on the rails after loosening the nuts.. It could be that yours is not forward enough to sit firmly on the velvety part, so it slides against it. Hard to say, really.
