I have a 1992 Z34 an I am putting in an aftermarket water temp sensor, but i want to keep the factory sensor as well. Does anyone know where i can get a T-fitting that would allow me to use 2 temp sensors in the same engine port?
Are you just wanting to tap into the wires basically? If so, just strip back some of the insulation, and solder away.
he is not talking about the wires. he istalking about the port on the lim. i sad just go to ace hardware and pick one up. then the stock one will still read and the aftermarket will read as well.
if you do that tho, you'll have a cavity that can either get too hot, or too cold and the coolant won't flow very well through it, you'd be better off drilling and tapping a new hole on the top of the thermostat housing for the new sensor.
--Dave.
