How to remove this panel
How do you remove this interior panel
i need the whole thing to come off, its the arm rest/clothed side panel thing on the back seats, u can see i outlined it in red, ill get a better pic if no one can tell from my pic
Take the surrounding plastic pieces around it off. Basically the plastic by the bottem and top of the doors, and the one on the rear. There are 2 plastic "pins"? that hold that piece on, so just pull the sucker off.
It will make it easier if you take out the rear seat when your doing that also.
alright thanks a ton you guys, if theres anything else please chime in
OH! it goes right back in too corrct, im not gonna have to go get a new one or somthing retarded right?
It goes back in, and they're very flexible :mrgreen:
I wrestled with them in both my cars, just go at it and you'll figure it out.
alright thanks, is the seatbelt retractor cover(s) floor and rear dash ones seperate peices? ill do this tonight when its cooler out
ack, i shoulda asked you guys first, i was trying to get to the sheet metal from the outside of the car from the inside to pop out a stupid dent, wheni took the quarter flare off, i discoverd it was big, and the metal was creased, so i couldnt suction cup it out, so now i gotta use a freaking dent puller, that punches a hole in the sheet metal, and pulls the metal out, grrr, this is crap! theres ANOTHER freaking thing of sheet metal, then im assuming mabye sound deadning material, then the outer sheet metal, great, and i had to pop rivits out from the track that the quarter flare was held on, because that was bent, and now the other halves of the rivits fell down, thell prolly rattle now, great :x
FUCK GM! why cant they just make things simple!!!! pull the piece off, and theres the sheet metal, but no! they have a piece of metal thats hexed on, then they put this weding metal wierd shitty lookin stuff around the cracks...
Open up your door. There should be a small vent there held in by 1 bolt. Undo that, and you should have some decent access to what you are looking for.
