harsh idle
every time i start my car it idles at 2000 and some times goes up to 3000. so if i keep pudhing on the gas a little it will somtimes go down or if i am in gear it will go down if i press on the gas a little it will go down. could it be a stick iac. please help i hate the idle
You've gotta reset the timing. I don't know the idle-relearn procedure offhand, but someone else might. If no one else posts it by the time I get home today, I'll look in my Haynes manual. I'm sure it's in there somewhere.
Idle relearn Procedure for the new FAQ Section :D
I don't know if that is your problem or not, but that link will give you the info to relearn the idle
do you have to do that procedure....wont it learn it after time??
Umm I don't believe it will "learn" it again unless you tell it to...aka doing the above procedure. :D
umm, actually i do think it relearns it if u drive long enough, but its prolly much easier to do that, cause my car idled like crap, after the batter died, and after a while it was just fine
even if it does, why do that when there's a simple re-learn procedure? that makes no sense to me...
thats what i said, its much easier to do that, as in the idle relearn process
wow this is the second post I've misread in less than 3 minutes while at work. I'm gonna get some coffee now to get me through this last hour...jesus christ... :oops:
only cuz i dont feel like letting it idle for 10 mins+ and yesterday i pulled the fuse on the ecm and after a max of driving a mile its already relearned
