White93z34 Posted July 19, 2005 Report Share Posted July 19, 2005 ok my buddies 88' CS intl. if we charge the a/c system it will charge but only a little, then it will not talke anymore freon at all, but it will hold the pressure, and from what i can tell the compressor is not turning on, and its certinally not blowing cold air, what gives? Quote Link to comment Share on other sites More sharing options...
GP1138 Posted July 19, 2005 Report Share Posted July 19, 2005 The compressor has to turn on to accept the refrigerant, I believe. I'm not sure if it circulates and therefore accepts more refrigerant or what. Sorry! Quote Link to comment Share on other sites More sharing options...
Brian P Posted July 20, 2005 Report Share Posted July 20, 2005 there's probably moisture in the system Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted July 20, 2005 Report Share Posted July 20, 2005 Sometimes, as in the case of a J-body I recently worked on, you have to turn the can upside-down even though common knowledge is you shouldn't. Even after vacuuming the system to remove all air/oxygen, even putting the can of R-134A in hot water, the system just wouldn't take anymore. Then I used a short refill hose so I could dump the liquid refrigerant right into the system and that worked. I hate J-bodies. Quote Link to comment Share on other sites More sharing options...
SigEpCutlass Posted July 20, 2005 Report Share Posted July 20, 2005 there's probably moisture in the system That would be my guess. I had to take my cutlass to the shop to recharge it because of that. I didn't know how to get rid of it. Thankfully at that time I had a friend who worked at a shop...hookups are great. 8) Quote Link to comment Share on other sites More sharing options...
