Cylinder heads/gaskets
Here's what you wanna see when you pull off the cylinder heads. Heh, check out the picture. Anyway, with all six cylinders full of antifreeze, do you think that it is just blown head gaskets, cracked cylinder heads, or what? At $36/pressure test on a cylinder head, i'm not entirely sure it's worth checking out for a free car with almost 300,000 miles on it that i've driven for two years. Anyone have any thoughts or advice?
did you drain all the coolant before you pulled the heads?
--Dave.
