Hello
I have a GTP 1994 automatic with the 4T60-e and I just by a Z34 1992 with 5speed manual HM-284, I was start the manual swap on my GTP, I find some trick for mecanical, this side it's OK, but
I do a search to find a some wiring connection and I don't find it....
If some people have a wiring diagram or swap connection ... because I find one on net ..but this guy just take the 4 wire on clutch pedal and reconnect, i don't no where, on automatic wire.... only the 4wire.. it's possible ?
If some body have a diagrame, or some pictures or etc... let a post ! :)
BIG thank's !
Yann
ia m not sure what you are asking....you want to know the wiring for the pedals?
humm .. I talk about 4 wire on pedal clutch ..but .. all wiring 'swap' ... i don't know whick wire goes where...
thank's
Yann
i did not hook any of that up....it is basicly the clutch safety so it does not start.....i just put a metal rod there
humm .. sorry :( I don't understand all your sentence ....
you don't 'play' with the 4 wire on clutch switch pedal ?
Yann
