frusciante fan Posted July 18, 2005 Report Posted July 18, 2005 getting my dual exhaust this week and wondering how it would affect sound, milage, etc. Quote
z34_nut Posted July 18, 2005 Report Posted July 18, 2005 Well you ask alot of questions. I guess thats good. But eh, no offence, but have you ever tryed the "search" botton? anyway, it should create a rasp of sorts, your car wont run well at all with it removed. It reduces a good amount of back-pressure. Quote
Cam'ron Posted July 18, 2005 Report Posted July 18, 2005 couldnt you recover "some" of the backpressure with a resonator in place of the cat? Quote
frusciante fan Posted July 18, 2005 Author Report Posted July 18, 2005 uhh don't you want less back-pressure? Quote
z34_nut Posted July 18, 2005 Report Posted July 18, 2005 \ said: uhh don't you want less back-pressure? you need a certain amount of backpressure for the engien to run efficiently. I would rather have a cat, then a resonator. Quote
JoroCorona Posted July 18, 2005 Report Posted July 18, 2005 Removing a cat on current cars is generally not a good thing unless your running a modified ECM. Right now, without the cat, the computer is gonna freak out and give you a check engine light. Its not going to know how rich/lean the engine is running and how clean/efficiant its running. Just leave the cat alone and run your duals cat back, or have them put a new cat in atleast. Quote
Cam'ron Posted July 18, 2005 Report Posted July 18, 2005 doesnt that depend on where your o2 sensor is... if it is in front of the cat it would not send any errors Quote
JoroCorona Posted July 18, 2005 Report Posted July 18, 2005 True, but I do believe the O2 system in the regal has an upstream and a downstream O2 sensor. I might be wrong however, I'm not exactly sure. Quote
Cam'ron Posted July 18, 2005 Report Posted July 18, 2005 i know my 2003 monte has sensors but they were all in front of the cat... i was going to take it out but decided to keep it in when i changed my exhaust to 3" from the cat back Quote
frusciante fan Posted July 18, 2005 Author Report Posted July 18, 2005 hmm i guess i'll just leave it then. god knows i hate that fucking light. the thing worries the piss out of me but it's helpful. Quote
Cam'ron Posted July 18, 2005 Report Posted July 18, 2005 figure out where your downdraft o2 sensor is you may get lucky... besides what is the absolute worst that can happen... i was told when i opened my 81 regal up that it could lead to floating exhaust valves or intake one or the other that was a few years ago so i put stronger springs into the new motor and had no problem... that 350 was 3" wide open dual exhaust(no cat, nothing) just a freeflow muffler you could look through and i never had a problem with it Quote
White93z34 Posted July 18, 2005 Report Posted July 18, 2005 \ said: Removing a cat on current cars is generally not a good thing unless your running a modified ECM. Right now, without the cat, the computer is gonna freak out and give you a check engine light. Its not going to know how rich/lean the engine is running and how clean/efficiant its running. Just leave the cat alone and run your duals cat back, or have them put a new cat in atleast. no, not at all. i got my euro with a piece of straight pipe in place of the cat. side by side its louder then my z34 and its a identicalpowertrain less the removed cat. as for a SES light, it will set off if i let the car idle for a LONG time, but i attribute it to my O2 sensor thats probably not quite right from all the time the euro ran bad, Quote
DaveFromColorado Posted July 18, 2005 Report Posted July 18, 2005 I've got my 92 Z-34 runnin' a straight pipe (no cat) and the rest of the system is stock - it's a bit louder behind the car, but not much. I do get a check engine light for an O2 sensor code, but only if I've been drivin' faster then 80 for more then 5 minutes, and if I slow under 80, the code goes away. I did notice I lost some gas milage when I did this, about 10% less per tank then when the catalytic converter was on there, but I also noticed a BIG increase in power (but my catalytic converter was pretty baddly plugged) I'm all for runnin' without a catalytic converter - when I was going to school (Hennepin Technicial College) we did some testing with the exhaust sniffers, and we didn't notice a big difference running a cat vs. open exhaust on fuel injected cars - --Dave. Quote
dbtk2 Posted July 18, 2005 Report Posted July 18, 2005 On an N/A car I'd leave it on there just to try to keep a little backpressure. My exhaust doesn't have enough backpressure on either of my cars because when there isn't any boost they pop and sound all raspy during acceleration. Once I get into the boost it stops sounding all raspy and sounds way better, but without boost it doesn't have enough backpressure. I'm pretty sure a '92 regal doesn't have an 02 sensor after the cat, but I could be wrong. Either way, I can't see it helping the performance a noticable amount on that car. Shawn Quote
Robby1870 Posted July 18, 2005 Report Posted July 18, 2005 two O2 sensors didnt start til 95 or 96. Take out cat, replace with glasspack or turbo tube or something that flows better, but still makes a little restriction. Quote
frusciante fan Posted July 18, 2005 Author Report Posted July 18, 2005 why does everybody give the regal so much shit? it's not that much slow than everything else...except the turbos but yeah. Quote
frusciante fan Posted July 18, 2005 Author Report Posted July 18, 2005 well i just talked to the guy doing it. bringing it in Thursday night and he should be done Friday afternoon. just hope i can keep it under $500. he is afterall only adding two mufflers, a splitter and some pipe. Quote
dbtk2 Posted July 18, 2005 Report Posted July 18, 2005 \ said: why does everybody give the regal so much shit? it's not that much slow than everything else...except the turbos but yeah. Where/how are people giving you shit about it??? I must be missing it. All I can see people saying is that removing the cat won't help a noticable amount, which it won't.... Not enough backpressure means less low end torque meaning worse fuel mileage and less useable power, you might gain horsepower on the topend but it won't be enough to make up for the lost torque and it will be less useable power because in daily driving you'll never see it. Shawn Quote
biff85ta Posted July 19, 2005 Report Posted July 19, 2005 I have NEVER noticed any lost anything from removing a cat from any car. Backpressure is never a good thing. If the car is OBD1 it should not set a code unless the O2 sensor is bad an OBD2 car will set a code but it will still run fine. The front O2 on does all the fueling changes the rear is just there to make sure the cat works. Quote
88Regal Limited Posted July 19, 2005 Report Posted July 19, 2005 Quoting the J-body.org. Dispelling the "backpressure" myth... The following excerpts are from Jay Kavanaugh, a turbosystems engineer at Garrett, responding to a thread on http://www.impreza.net regarding exhaust design and exhaust theory: "Howdy, This thread was brought to my attention by a friend of mine in hopes of shedding some light on the issue of exhaust size selection for turbocharged vehicles. Most of the facts have been covered already. FWIW I'm an turbocharger development engineer for Garrett Engine Boosting Systems. N/A cars: As most of you know, the design of turbo exhaust systems runs counter to exhaust design for n/a vehicles. N/A cars utilize exhaust velocity (not backpressure) in the collector to aid in scavenging other cylinders during the blowdown process. It just so happens that to get the appropriate velocity, you have to squeeze down the diameter of the discharge of the collector (aka the exhaust), which also induces backpressure. The backpressure is an undesirable byproduct of the desire to have a certain degree of exhaust velocity. Go too big, and you lose velocity and its associated beneficial scavenging effect. Too small and the backpressure skyrockets, more than offsetting any gain made by scavenging. There is a happy medium here. For turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end. Downstream of the turbine (aka the turboback exhaust), you want the least backpressure possible. No ifs, ands, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turboback exhausts is valid. Here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure. Again, less pressure downstream of the turbine is goodness. This approach minimizes the time-to-boost (maximizes boost response) and will improve engine VE throughout the rev range. As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.? "As for the geometry of the exhaust at the turbine discharge, the most optimal configuration would be a gradual increase in diameter from the turbine's exducer to the desired exhaust diameter-- via a straight conical diffuser of 7-12° included angle (to minimize flow separation and skin friction losses) mounted right at the turbine discharge. Many turbochargers found in diesels have this diffuser section cast right into the turbine housing. A hyperbolic increase in diameter (like a trumpet snorkus) is theoretically ideal but I've never seen one in use (and doubt it would be measurably superior to a straight diffuser). The wastegate flow would be via a completely divorced (separated from the main turbine discharge flow) dumptube. Due the realities of packaging, cost, and emissions compliance this config is rarely possible on street cars. You will, however, see this type of layout on dedicated race vehicles. A large "bellmouth" config which combines the turbine discharge and wastegate flow (without a divider between the two) is certainly better than the compromised stock routing, but not as effective as the above. If an integrated exhaust (non-divorced wastegate flow) is required, keep the wastegate flow separate from the main turbine discharge flow for ~12-18" before reintroducing it. This will minimize the impact on turbine efficiency-- the introduction of the wastegate flow disrupts the flow field of the main turbine discharge flow. Necking the exhaust down to a suboptimal diameter is never a good idea, but if it is necessary, doing it further downstream is better than doing it close to the turbine discharge since it will minimize the exhaust's contribution to backpressure. Better yet: don't neck down the exhaust at all. Also, the temperature of the exhaust coming out of a cat is higher than the inlet temperature, due to the exothermic oxidation of unburned hydrocarbons in the cat. So the total heat loss (and density increase) of the gases as it travels down the exhaust is not as prominent as it seems. Another thing to keep in mind is that cylinder scavenging takes place where the flows from separate cylinders merge (i.e. in the collector). There is no such thing as cylinder scavenging downstream of the turbine, and hence, no reason to desire high exhaust velocity here. You will only introduce unwanted backpressure. Other things you can do (in addition to choosing an appropriate diameter) to minimize exhaust backpressure in a turboback exhaust are: avoid crush-bent tubes (use mandrel bends); avoid tight-radius turns (keep it as straight as possible); avoid step changes in diameter; avoid "cheated" radii (cuts that are non-perpendicular); use a high flow cat; use a straight-thru perforated core muffler... etc.? "Comparing the two bellmouth designs, I've never seen either one so I can only speculate. But based on your description, and assuming neither of them have a divider wall/tongue between the turbine discharge and wg dump, I'd venture that you'd be hard pressed to measure a difference between the two. The more gradual taper intuitively appears more desirable, but it's likely that it's beyond the point of diminishing returns. Either one sounds like it will improve the wastegate's discharge coefficient over the stock config, which will constitute the single biggest difference. This will allow more control over boost creep. Neither is as optimal as the divorced wastegate flow arrangement, however. There's more to it, though-- if a larger bellmouth is excessively large right at the turbine discharge (a large step diameter increase), there will be an unrecoverable dump loss that will contribute to backpressure. This is why a gradual increase in diameter, like the conical diffuser mentioned earlier, is desirable at the turbine discharge. As for primary lengths on turbo headers, it is advantageous to use equal-length primaries to time the arrival of the pulses at the turbine equally and to keep cylinder reversion balanced across all cylinders. This will improve boost response and the engine's VE. Equal-length is often difficult to achieve due to tight packaging, fabrication difficulty, and the desire to have runners of the shortest possible length.? "Here's a worked example (simplified) of how larger exhausts help turbo cars: Say you have a turbo operating at a turbine pressure ratio (aka expansion ratio) of 1.8:1. You have a small turboback exhaust that contributes, say, 10 psig backpressure at the turbine discharge at redline. The total backpressure seen by the engine (upstream of the turbine) in this case is: (14.5 +10)*1.8 = 44.1 psia = 29.6 psig total backpressure So here, the turbine contributed 19.6 psig of backpressure to the total. Now you slap on a proper low-backpressure, big turboback exhaust. Same turbo, same boost, etc. You measure 3 psig backpressure at the turbine discharge. In this case the engine sees just 17 psig total backpressure! And the turbine's contribution to the total backpressure is reduced to 14 psig (note: this is 5.6 psig lower than its contribution in the "small turboback" case). So in the end, the engine saw a reduction in backpressure of 12.6 psig when you swapped turbobacks in this example. This reduction in backpressure is where all the engine's VE gains come from. This is why larger exhausts make such big gains on nearly all stock turbo cars-- the turbine compounds the downstream backpressure via its expansion ratio. This is also why bigger turbos make more power at a given boost level-- they improve engine VE by operating at lower turbine expansion ratios for a given boost level. As you can see, the backpressure penalty of running a too-small exhaust (like 2.5" for 350 hp) will vary depending on the match. At a given power level, a smaller turbo will generally be operating at a higher turbine pressure ratio and so will actually make the engine more sensitive to the backpressure downstream of the turbine than a larger turbine/turbo would. As for output temperatures, I'm not sure I understand the question. Are you referring to compressor outlet temperatures? The advantage to the bellmouth setup from the wg's perspective is that it allows a less torturous path for the bypassed gases to escape. This makes it more effective in bypassing gases for a given pressure differential and wg valve position. Think of it as improving the VE of the wastegate. If you have a very compromised wg discharge routing, under some conditions the wg may not be able bypass enough flow to control boost, even when wide open. So the gases go through the turbine instead of the wg, and boost creeps up. The downside to a bellmouth is that the wg flow still dumps right into the turbine discharge. A divider wall would be beneficial here. And, as mentioned earlier, if you go too big on the bellmouth and the turbine discharge flow sees a rapid area change (regardless of whether the wg flow is being introduced there or not), you will incur a backpressure penalty right at the site of the step. This is why you want gradual area changes in your exhaust." Quote
frusciante fan Posted July 19, 2005 Author Report Posted July 19, 2005 it was refering to the site in general. thanks for the info limited Quote
94cutlatized Posted July 22, 2005 Report Posted July 22, 2005 i got my cat removed in my 94 cutlass, just before i put dual exhaust n it, i noticed a significant difference in performance, after i got the dual exhaust i noticed greater performance. i also got really nice sound out of dynomax's bullet racing muffler as for the "service engine soon", well, its been on since i put in a bigger radiator, so i couldnt tell if it was the cat removal that caused it. Quote
