ns87 Posted July 17, 2005 Report Posted July 17, 2005 I'm not gonna lie. I know practically nothing about engines. Anywho, head gasket needs to be replaced. It only leaks oil out of the engine, not in coolant, or coolant into engine. Whenever I get this fixed, is it worth while to get the timing belt/chain replaced? Do they have a tendency to break on the 3.1MPFI? Quote
Robby1870 Posted July 17, 2005 Report Posted July 17, 2005 Ive only heard of a few timing chains breaking, plus, you dont have to remove the timing cover to change a head gasket. Where is it leaking oil from? Just curious. Quote
Supreme Cutlass Posted July 18, 2005 Report Posted July 18, 2005 The timing chains are usually rock solid unless the engine has seen some abuse... like mine.. Quote
ns87 Posted July 18, 2005 Author Report Posted July 18, 2005 It leaks from where the top end of the engine meets the lower half or "bottom end". lol I know enough about engines to know that. Basically, its where the engine doesn't have a 60 degree bend anymore and its just flat again if you cut it in half. Quote
JoroCorona Posted July 18, 2005 Report Posted July 18, 2005 It leaks from where the top end of the engine meets the lower half or "bottom end". lol I know enough about engines to know that. Basically, its where the engine doesn't have a 60 degree bend anymore and its just flat again if you cut it in half. O_o Well apparently I dont know enough about engines... Quote
z34_nut Posted July 18, 2005 Report Posted July 18, 2005 It leaks from where the top end of the engine meets the lower half or "bottom end". lol I know enough about engines to know that. Basically, its where the engine doesn't have a 60 degree bend anymore and its just flat again if you cut it in half. ???? Quote
DaveFromColorado Posted July 18, 2005 Report Posted July 18, 2005 if you're talking about directly under the throtle body, it might be the oil pump drive o-ring. Also, I've seen oil leaking from under the lower intake manifold along the block, typically the head gaskets on these engines won't have an external oil leak. --Dave. Quote
Guest TurboSedan Posted July 18, 2005 Report Posted July 18, 2005 if you're talking about directly under the throtle body, it might be the oil pump drive o-ring. Also, I've seen oil leaking from under the lower intake manifold along the block, typically the head gaskets on these engines won't have an external oil leak. --Dave. that's what it is sounding like to me, as they are notorious for leaking there. the o-ring gets hardened and brittle over time and oil will seep past it. it's a very easy fix on the 3.1 MPFI engine. Quote
ns87 Posted July 18, 2005 Author Report Posted July 18, 2005 Ok. Heres a picture. The black strip on the bottom is the long side of the power steering pump. I'm looking down past the cylinders toward the bottom of the engine. Now the other picture is on the other side, by the very wide accordian type hose that goes toward the air box. Thats why I thought it was the headgasket. Also a mechanic told me it was the headgasket, but I wouldnt take his word for it. Quote
sonyman87 Posted July 18, 2005 Report Posted July 18, 2005 rofl. Your headgaskets are fine that ring in very exact center of that picture you posted is the Oilpump seal. The O-ring is nutorious for going out on it. on your car it wouldnt be very hard to fix this problem. and dont take it to a stealer ship. they will "RAPE" you of your money for this. if you are not comfortable doing this yourself visit a local repair shop and they should able to do this in a few hours tops. Quote
DaveFromColorado Posted July 18, 2005 Report Posted July 18, 2005 I'd say that's the lower intake manifold gasket leaking - and maybe a SMALL bit from the o-ring (extremely small bit) and I'd recomend replacing that o-ring at the same time when you do the manifold gaskets. --Dave. Quote
