wbody1973 Posted July 16, 2005 Report Share Posted July 16, 2005 95 gp gtp -dic resets to zero everytime you start the car -keyless entry won't lock the doors -keyless entry will only open the drivers side door -abs light on the guage cluster is on constantly(no break problems that i know of) -no lights come on when i open the door. -no interior coack lights what soever when you try to manually turn them on. All this stuff happened at once just like that. I pulled a couple fuses, and seen no problem. Is there an electrical box somewhere under the dash that maybe went bad. I know in my father-in-laws interpid, he had this problem with interior stuff going all crazy on him and this is what it was. If so, where is this unit located, and is it 95 gtp specific...??? Any other ideas??? Quote Link to comment Share on other sites More sharing options...
THe_DeTAiL3R Posted July 16, 2005 Report Share Posted July 16, 2005 Check your connection from the batt to the pos aux box. It may just be a little lose. I had problems with my car- sometimes wouldn't start, ABS light would come one sometimes, window wouldn't work, stereo would "reboot".. all along it was just one stupid wire! Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted July 16, 2005 Report Share Posted July 16, 2005 Yep, the Aux Post nut working itself loose is a common problem on these cars. The ABS light coming on is a dead giveaway to an electrical problem - it will illuminate before your "battery" light does! Actually, the ABS system is very sensitive to minute changes in voltage, so that's what causes the light to illuminate. I try to snug up my Regal's Aux Post nut at least every-other time I get gas, cause it always seems to loosen up a bit (especially in the summer.) I even put another nut on top of the origninal nut and it still manages to work its way loose ... Quote Link to comment Share on other sites More sharing options...
wbody1973 Posted July 17, 2005 Author Report Share Posted July 17, 2005 Checked it. Still not the problem. any other suggestions...??? Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted July 17, 2005 Report Share Posted July 17, 2005 It sounds to me like the CTSY fuse is blown, otherwise the whole panel where that fuse resides is out. Check the battery cable that connects to the passenger side underhood fuse panel. I remember hearing about that cable breaking loose also. IIRC, one or more of the large fuses underhood supplies the voltage to the fuse box in the passenger compartment... Quote Link to comment Share on other sites More sharing options...
