slick Posted July 13, 2005 Report Posted July 13, 2005 Slot-ported box to be exact. Tuned to 33hz if possible. Subwoofer is a 12" Alpine Type R, model # SWR-1242D. It needs to be able to fit in the trunk of my Z34. I can get height measurements if needed, just incase w-body trunk heights are different. I can take out my rear seat if needed to get this puppy in there. Thanks fellas. Quote
1990lumina Posted July 13, 2005 Report Posted July 13, 2005 Just in case your back seat is like mine....removing the seat will not allow access to the trunk. There are a metal support all across the back. However, your car could be different and probably is. Quote
Puggsley456 Posted July 14, 2005 Report Posted July 14, 2005 Do you need exactly 33Hz because I have a couple here. Ones 1.5cubes at 26Hz. And the other is 1.6cubes at 28HZ. If you want them just let me know. Quote
J Posted July 14, 2005 Report Posted July 14, 2005 go to elemental designs and design one and then just get the deminsions. Hell if i can build mine to spec so can you Quote
Puggsley456 Posted July 14, 2005 Report Posted July 14, 2005 go to elemental designs and design one and then just get the deminsions. Hell if i can build mine to spec so can you Their box designer doesnt tell you how long to make the port. Quote
slick Posted July 15, 2005 Author Report Posted July 15, 2005 Do you need exactly 33Hz because I have a couple here. Ones 1.5cubes at 26Hz. And the other is 1.6cubes at 28HZ. If you want them just let me know. The one at 28HZ will do. Thanks! Quote
1990lumina Posted July 15, 2005 Report Posted July 15, 2005 OT - but you guys are confusing the hell out of me with 4 different ppl with the same sig picture lol....that's usually what I go by for knowing who's posted what...but christ your making it hard on me lol Quote
MonteCarloChick Posted July 15, 2005 Report Posted July 15, 2005 [] <--- a box for youuuuuuuuuu awesome sound y0 Quote
Puggsley456 Posted July 15, 2005 Report Posted July 15, 2005 Here you go. I modified this one. The tuning should be arround 29hz once your sub is mounted into it. Quote
