low idel
silver_92_z34
Hi guys I have a low idel prob. I have a 92 Z with an auto. underdrive pully, modded air box, rapid fire 8 plugs. The idels at 500rpm stoped in gear. The timming belt is like 60k old. Off idel the car is a frigin rocket. I run top engine cleaner and injector cleaner with now improvment. If you have any ideas please help.
Richard Garberson
is the idle smooth at 500rpms?? Your IAC maybe worn out or the pintle on its valve maybe the wrong distance. Maybe your computer is telling it to idle that low. So, you may try disconnecting the battery, and reseting idle. It is sort of hard to diagnose. Surely someone else will have some ideas.
-Robby
hook it up to a scanner (if you have access to one) and see if anyhting is out of the ordinary.
