turbo question, need reply ASAP!
is it worth me buying a turbo setup to install on a 2.8? and if so, what else needs to be done to make the setup work? i know nothing about the turbo motor...basically i'm just asking if it's pretty much a bolt-on upgrade
A 2.8 would probably handle a turbo just fine. If the kit is much cheaper than buying a TGP motor, I'd think about it. You've already got the 5-speed so the memcal would have to be tuned differently anyways...
And to answer your question, no I wouldn't consider this a "bolt on" upgrade.. little more involved then that.
Nice looking car BTW! :thumbsup:
Beings that your 2.8 5 speed is mint.....Id keep it that way and find another W to turbo.
If you can actually find a complete turbo system cheaper than you can a TGP motor, then go for it. (I just find that happening VERY VERY VERY unlikely) I didn't see you had the 282. Beef it up a little bit, and you should have no trouble bolting it up to the LG5.
so what are the major things i'm looking at? the setup i found has the turbo, manifolds, and downpipe. it's only like $250
Guest TurboSedan
are you reffering to the TGP turbo/manifolds/crossover pipe and downpipe going for $250 on EBAY?
didn't know this was such a talked about thing already. i need to get online more often. since i don't know what the hell i'm talking about, what is a lot more stuff? i really don't mean to sound like an idiot
