ghostwhite91 Posted July 9, 2005 Report Share Posted July 9, 2005 Having problem with vent. system. All the options work, the vacuum actuators are working, pulled the squirrel cage fan, works fine. Pulled the top part of the dash off to look for lodged object ( rag, etc. ). Cannot see anything in any vents. Could one of the flaps or linkages be broken from the actuators, not opening? There is vacuum going to each actuator. What else could it be? Is there a filter clogged that I don't know about? Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted July 9, 2005 Report Share Posted July 9, 2005 Edit: I can't read. Quote Link to comment Share on other sites More sharing options...
DaveFromColorado Posted July 10, 2005 Report Share Posted July 10, 2005 so I'm guessing your problem isn't that you can't select the mode (ie: where the airflow is going) but that you don't have enough volume of air ... if I'm correct in assuming that, then your problem is probably the evaporator core for the A/C in the car, those tend to collect all sorts of debris and clog up over time, usually because of extremely small leaks that cause the oil to collect on it which will hold the dirt and other objects there. I can't remember what the vent system looks like on the W-bodies (mine is parked in storage right now) but if I remember correctly, it shouldn't take that* long to repair or just clean out. --Dave. Quote Link to comment Share on other sites More sharing options...
ghostwhite91 Posted July 11, 2005 Author Report Share Posted July 11, 2005 ^^^^ Yah, someone said to me the exact same thing, so it's coming out I guess. Thank you and will post back if needed. Quote Link to comment Share on other sites More sharing options...
solid_raiden223 Posted July 11, 2005 Report Share Posted July 11, 2005 I had to use a wire brush to clean mine on my 1990 buick lesabre... pretty easy... i got to do it on my friends 92 pontiac GP soon so... oh well Quote Link to comment Share on other sites More sharing options...
