Psych0matt Posted July 6, 2005 Report Share Posted July 6, 2005 Like the title says, i turn on the ac and nothing happens except blowing out the vents. I was going to get it recharged, but it was full. so, does that mean I just need to get a new compressor? or whats going on!? Quote Link to comment Share on other sites More sharing options...
Canada Posted July 6, 2005 Report Share Posted July 6, 2005 Well......either the compressor is junk, or it isn't being told/allowed to turn on. Perhaps there is a bad sensor....or maybe your control head is working....there are a ton of options. Quote Link to comment Share on other sites More sharing options...
Turbocharged400sbc Posted July 6, 2005 Report Share Posted July 6, 2005 find the AC compresor clutch relay and manually activate it (jumper it) if the clutch turns on then ther is a problem with the primary side of the realay, it's circuit, or the high/low side sensors or controll head. does the control unit have a light for AC ? if it's not turning on start there... if it is turning on then there is a possibility of a bad sensor and or circuit...somewhere... i have Mitchell on Demand...but i have to print it then scan it to post it (damn cut and paste dont work with mitchell lol james Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted July 7, 2005 Report Share Posted July 7, 2005 If the pressure is too low, it won't allow it to turn on. You have to jumper it. Quote Link to comment Share on other sites More sharing options...
jeremy Posted July 7, 2005 Report Share Posted July 7, 2005 If the pressure is too low, it won't allow it to turn on. I was going to get it recharged, but it was full. Quote Link to comment Share on other sites More sharing options...
Whiskey River Posted July 7, 2005 Report Share Posted July 7, 2005 Don't go by static pressure. It will be the same regardless of how much refrigerant is in the system. As an example, a 20 lb. tank will have the same static pressure as a 1 lb can. The static pressure is heat related. Quote Link to comment Share on other sites More sharing options...
