Cat replacement
I'm looking to replace my noisy one with a high flow. I've been looking around on ebay, and have also heard that the magnaflow car sound ones ae good
like this one
but was wondering if something like this would be good as well (it's cheaper)
here
or any other suggestions?
EDIT:
any reactions to this?
Gut the stock. Likw white93Z34 did on his 'maro. :D
either way, I have to get it cut off and welded back on, i might as well spend a little bit to get one. mine just rattles so much at 2000+ rpm, so fricken annoying
If you have no emissions just cut it out and weld a straight pipe in.
My RX-7 is supposed to have 3 cats...but it only has one remaining, the rest is all straight pipe.
well, that was an option too. BUT I don't know anyone to weld it in, and shops wont do it, so I'm kinda screwed for now, unless anyone knows someone around the anderson/muncie area that would do it...
on my camaro i gutted the cat out of necessity, it was cloged. i need a cat in my county, but it dosen't have to work. so i smashed the guts out, works fine for now. i'mm probably run a chunk of straight pipe through the cat so the exhaust sounds better.
