ok i have a 94 z34 and this first happened when i switched out my engine. so i turned the car off and it went away. but today it was raining- like it does everyday in florida and it can on again. so i turned the car off and it went away. what the heck what would cause it to do this
bad sensor, or a bad wire somewhere, it's hard to tell without knowing which trouble code(s) it's putting out.
--Dave.
how do you know the trouble code. and why do you think it is something bad if it only happened 1 after the rebuild.
you find out what the trouble code is after you scan your car with a scanner, and without that information (that is the codes or whatever else the scanner tells you) you have no idea if it's a serious, or a simple problem that either needs to be fixed right away, or not at all.
I don't care if it's something bad, it's not my car, I was merely trying to help.
--Dave.
Check the cable from the batt to the pos aux mine was lose causing the ABS light to come on.
yep, happened to me during the winter and went the whole winter with no ABS. It was too damn cold out to go and figure out what was wrong. Although as it turns out that was the last thing I looked at :lol:
More than likely its either the aux because if it was a senor, it would have happened more than once
