Sputtering all over the tach
hey guys, my car's unhappy. the problem is that the car sputters and hesitates horrendously under anything past 2% throttle anywhere on the tach.though sometimes I get these spurts of full power the on occasion makes the tires chirp. Also, idle might be a touch rough. the plugs are new as of 300 miles ago and the wires are good. I dont know how to check the coils. thanks for the advice.
OK i've checked the front 3 injectors and they're fine, I'll avoid taking off the plenum if I can avoid it. anyhow, how would i goi about checking coils?
Check your EGR valve to see if it's moving when you rev the engine. It should not do anything in park or neutral.
check fuel pressure at the rail, you could have a bad fuel pump or plugged fuel filter
