sonyman87 Posted June 30, 2005 Report Posted June 30, 2005 i just hooked up the wheels no problem. boltpatter is a perfect match.. 1 problem. the damn steel sidewall rubbs against my break calipers! fuck me. where is a good place to get spacers cheep and fast! Quote
kuntzie Posted June 30, 2005 Report Posted June 30, 2005 good luck... when i put the 1998 grand prix rims on my 1990 i needed psacer... the the studs were too short and they like to charge big coin for them Quote
sonyman87 Posted June 30, 2005 Author Report Posted June 30, 2005 good luck... when i put the 1998 grand prix rims on my 1990 i needed psacer... the the studs were too short and they like to charge big coin for them well i fond out i only need about 3mm. i seen some for 9.99 at 6mm which is still fine. the rims have a very thin wall so there is litteraly .75inches of stud to grab onto. with that 6mm spacer (already tested with washer) there is .6inches of stud to grab onto, i think thats plenty right? Quote
buckethead Posted June 30, 2005 Report Posted June 30, 2005 sounds ok.. I think anything over half an inch and you're good. Quote
jeremy Posted June 30, 2005 Report Posted June 30, 2005 what rims did you get? Also, I would recommend getting the smallest spacer that you need. Quote
sonyman87 Posted June 30, 2005 Author Report Posted June 30, 2005 what rims did you get? Also, I would recommend getting the smallest spacer that you need. 2003 & 04? Impala steelies. http://www.w-body.com/forum/viewtopic.php?t=30927 Quote
