Kalgorn Posted June 28, 2005 Report Posted June 28, 2005 I didn't think this belonged in Member Mobiles since I'm not really showing off my car, just something quick I did to it. I didn't repaint the whole bumper; just sanded down the bad spot and the lower valence but I sprayed a coat onto the spots where there were a lot of rock chips. I don't think the pictures make it look as good as it does. But, no matter what, it still looks tons better than what it did. BEFORE: AFTER: EDIT: I still have to throw down at least one more coat. It started to chip off on the drive back to school yesterday (kind of expected it to... but I hoped it wouldn't). Quote
chadz34 Posted June 28, 2005 Report Posted June 28, 2005 Looks alot better. What kind of paint did you use? You should have sanded it and primed it. It stays on better. Quote
Kalgorn Posted June 28, 2005 Author Report Posted June 28, 2005 I did sand it. I used 60, then 220, then wet sanded with 400. I didn't use primer though because I didn't feel it was necessary. I used spray paint meant specifically for plastic that said no primer was needed so I didn't worry about it. Quote
chadz34 Posted June 28, 2005 Report Posted June 28, 2005 Cool. It definately looks better you did a good job. Quote
Dannymik Posted June 29, 2005 Report Posted June 29, 2005 nice, you'll get better each time you attempt that kind of repair Quote
Hairdo12 Posted June 29, 2005 Report Posted June 29, 2005 There is a coating they make that you should put down on the plastic before any type of primer or paint. It makes the paint stick to plastic. Quote
Stevo Posted June 29, 2005 Report Posted June 29, 2005 There is a coating they make that you should put down on the plastic before any type of primer or paint. It makes the paint stick to plastic. Actually it's a flex agent thats put into the paint. Usually put into cheap ass integrated clear coat paints. Quote
z34Phoenix Posted June 29, 2005 Report Posted June 29, 2005 there is a new kind of primer out there that almost foams after it sprayed. it would be perfict for this kinda work. i had a gash about 1/4 inch deep in the side skirt on my Z and it worked perfict to fill and smooth it. and since it was primer, i just painted right over it when i was done. they have it in red and grey. i would still use one or two coats of sandable primer after that stuff and a few layers of paint and clear, but its the best way i know of yet Quote
stockgp Posted June 29, 2005 Report Posted June 29, 2005 there is a new kind of primer out there that almost foams after it sprayed. it would be perfict for this kinda work. i had a gash about 1/4 inch deep in the side skirt on my Z and it worked perfict to fill and smooth it. and since it was primer, i just painted right over it when i was done. they have it in red and grey. i would still use one or two coats of sandable primer after that stuff and a few layers of paint and clear, but its the best way i know of yet any details? lik,e a name and place to buy it? Quote
Schudini Posted July 1, 2005 Report Posted July 1, 2005 there is a new kind of primer out there that almost foams after it sprayed. it would be perfict for this kinda work. i had a gash about 1/4 inch deep in the side skirt on my Z and it worked perfict to fill and smooth it. and since it was primer, i just painted right over it when i was done. they have it in red and grey. i would still use one or two coats of sandable primer after that stuff and a few layers of paint and clear, but its the best way i know of yet any details? lik,e a name and place to buy it? Yeah, I would also like to know. That would be ideal for my repairs. Quote
