bogart219 Posted June 26, 2005 Report Share Posted June 26, 2005 Hey folks, Great forum here. Wonder if anyone ran into this before. 94 GP se, 3.1. The gear indicator on the dash is not working. When you go from park to drive, the little orange indicator does not move. Can't tell what gear the car is in by looking at the display. Not a big deal but got this car for the kid and would like to correct this if its not to hard. Any suggestions would be most welcomed! Quote Link to comment Share on other sites More sharing options...
one hot GTP Posted June 26, 2005 Report Share Posted June 26, 2005 my old cougar had the same problem--i just counted how many gears were passed b4 i got to the one i wanted--it became second nature after awhile you just know--but i suppose you could fix it i dont know how though Quote Link to comment Share on other sites More sharing options...
88Regal Limited Posted June 26, 2005 Report Share Posted June 26, 2005 I believe when you shift the collom turns too, and it is a little wire type thingie that plugs into the moving collom, so when the collom moves from 1 gear to another, it pulls the string attached to the orange pointer. How it works in my camaro, probably the same here. Quote Link to comment Share on other sites More sharing options...
runt Posted June 26, 2005 Report Share Posted June 26, 2005 My guess would be to pull the gauges out and see if there is a cable attached to the indicator. If not, you may either need to reattach it, or simply try to tighten the tension on it. I had the same problem in my dad's old Explorer, and all we did was (as I said above...lol) pull the cluster out and reattach the small cable. Quote Link to comment Share on other sites More sharing options...
bogart219 Posted June 26, 2005 Author Report Share Posted June 26, 2005 Yeah , I'll have to see if I can get in there and see if a cable or string came off or something. thanks for your replys Quote Link to comment Share on other sites More sharing options...
