Jon89le Posted June 25, 2005 Report Posted June 25, 2005 Starting last week my car started having starting problems which i chucked to my starter going. I would turn the key and nothing, no click. Then on like the 3rd try itd start. Its in a week its gotten exponentially worse. Then the other day at work it happen. I threw it in Neutral and it started, which is now how i have to start it most of the time. Is this my Park/Neutral saftey switch? If so, where is it located to be replaced? Any help is appreciated. Quote
dsgrntld187 Posted June 25, 2005 Report Posted June 25, 2005 I believe the P/N switch is on the top of the tranny, if I remember right. Mine does the same thing, and I believe thats what mine is also. Quote
DiscoStudd Posted June 26, 2005 Report Posted June 26, 2005 Yes, that sounds exactly like a P/N safety switch going out. IIRC, it's underneath the airfilter box (okay, not directly but you can see it a lot better if you remove the air box.) A Hayne's manual shows you how to change it out... Quote
1990lumina Posted June 26, 2005 Report Posted June 26, 2005 My car is the opposite. It will not start in neutral - it won't even click. When you have it in neutral and turn the key all the guages become active just like when you start it, but no crank... in park I've never had a problem with it not startingt hough... sorry to hijack though, back on topic Quote
dsgrntld187 Posted June 26, 2005 Report Posted June 26, 2005 My car is the opposite. It will not start in neutral - it won't even click. When you have it in neutral and turn the key all the guages become active just like when you start it, but no crank... in park I've never had a problem with it not startingt hough... sorry to hijack though, back on topic Mine too, if in neutral you have to have it partially in the reverse slot (but still in neutral) to engage it. Quote
