one hot GTP Posted June 25, 2005 Report Posted June 25, 2005 i was driving to work today, and as i pulled up my alt. lite came on. i had my b/f follow me cuz its an 18 mile drive -- about 10 miles later the lite went off. before we left for home he tested the battery and it was fully charged when we got home after 18 miles it was still fully charged any ideas? Quote
glock19 Posted June 25, 2005 Report Posted June 25, 2005 How many volts was the alternator putting out? Measure the voltage with the car off. Should be around 12.6V or so. Turn the car on, the voltage should jump up to 13.5-14V and then gradually go down to 13.2 to 13.5. It is possible the alternator is putting out barely enough voltage to keep the battery charged, but if any accessories kick on, that voltage could drop quickly and trigger the light. Glock Quote
one hot GTP Posted June 25, 2005 Author Report Posted June 25, 2005 yeah the numbers were ther --i didnt run any headlights ,wipers, radio driving home, i just thought it was odd the light was on then went off it Quote
cutlsp Posted June 25, 2005 Report Posted June 25, 2005 you could have a short that is interment :? Quote
DiscoStudd Posted June 25, 2005 Report Posted June 25, 2005 Is your ABS light lit up before/during/after the battery light being lit? The sure sign of impending alternator failure on a late model GM is the ABS light lighting up a few minutes before the battery light (and it's always in that order, too...) Quote
White93z34 Posted June 25, 2005 Report Posted June 25, 2005 i'd say its on its way out, i've had cars do that to me before, change it before it leaves you somewhere. Quote
one hot GTP Posted June 25, 2005 Author Report Posted June 25, 2005 Is your ABS light lit up before/during/after the battery light being lit? The sure sign of impending alternator failure on a late model GM is the ABS light lighting up a few minutes before the battery light (and it's always in that order, too...) i noticed a quick flash of orange in the middle of the cluster but when i looked it was gone that was after the batt light came on i response to White93z34 i had planned on it cuz ive been stuck too thanks for the help Quote
